Go Back  ClubLexus - Lexus Forum Discussion > Lexus Model Forums > GS Models > GS - 2nd Gen (1998-2005) > Performance
GS300 changed spark plugs to TM plugs & now code P0154, vsc, vsc off light, abs light >
Old 12-21-13, 08:49 PM
GregCon
Well, after some messing around I fixed the issue so I thought I would post the fix here as a follow up.
The car was showing a P0154 code which is no activity on the Bank 2 Sensor 1.
I used the scanner to watch the STFT and O2 sensor voltage for the Bank 2 Sensor 1 O2 sensor and in general the numbers were not what they should be...in fact they were either 0 or barely above it for the voltage, and there was a lot of STFT correction going on which meant the computer was trying to richen up the mixture to compensate for no inputs from the O2 sensor.
I replaced the sensor with a new Denso unit and the readings were good for a few miles, but then they degraded quickly and the CEL and VSC lights came back.
I started looking at the wiring harness, where the O2 sensor plugs in, and it looked perfect. It was not something I disconnected during the plug/valve cover gasket change, either. But then I pulled on each of the 4 wires and one came right out of the connector. I pulled the terminal out, and you could see where it had been over-crimped when new. In fact, it looked like it spent the past 8 years and 121,000 miles working by proximity contact only. I am sure the work I did caused the harness to move a little which was just enough to move the wire out of contact.
So, I soldered the terminal box on to the wire (you can't recrimp this type of terminal) and it works great now. No more lights.
The connector/terminal arrangement is really dainty for an underhood part, IMO. If it ever gives trouble again I will replace the entire 4 pin connector with a 4 pin GM-style Weatherpak connector which uses a mechanically stronger terminal and is easy to buy. But for now it is working well and I doubt it will break again.
GregCon is offline
Old 08-13-18, 11:22 AM
kayuwong
Default P0154 after valve cover job
Can anyone help me out on this issue, I even changed B2S1 sensor and still get chk engine light.
kayuwong is offline
Old 01-07-19, 01:17 PM
DuckyB
Default Ecu
I had the same issue and code. After replacing Bank 2 Senor 1 with no cure I took to the dealer . Banks 1 & 2 Downstream sensors and ECU are bad. very expensive repair, if taken to a Dealer
DuckyB is offline
Old 01-07-19, 02:29 PM
kayuwong
Default Use a safety pin to check circuit
kayuwong is offline
Old 01-07-19, 02:38 PM
kayuwong
Default Wire was broken inside of the harness
My mechanic broke the wire by flipping the TB on the side without disconnecting the harness, it took me a long time to find out the problem. Wiggle each wire and pull gently and test, I end up just replace that pin inside the wire harness, good luck.
kayuwong is offline
Quick Reply: GS300 changed spark plugs to TM plugs & now code P0154, vsc, vsc off light, abs light
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
