Need Wheel/Rim and Tire size advice GX470
Old 01-12-19, 04:51 AM
MTD1
MTD1's Avatar
Thank you. I bought them on Ebay:
https://www.ebay.com/itm/Toyota-OEM-...D/253054119666
Old 01-12-19, 08:55 AM
MrAlonzo
MrAlonzo's Avatar
Originally Posted by Arailt
Nice! Black on the white is a great look.
FWIW, my TRD Pro wheels are 17x7 w/ +4mm offset.
Here's what 275/70s look like with no lift. I had to push the front fender well forward about 2" to clear them. Other than that, no modifications required.
With the +4 offset you didnt have any issues with rubbing on the calibers? Thx,
looks dope!
Old 01-12-19, 08:57 AM
MrAlonzo
MrAlonzo's Avatar
Originally Posted by MTD1
Awesome! I did notice these are 17x8 tho.. hmm is that going to effect anything?
Old 01-12-19, 06:19 PM
MTD1
MTD1's Avatar
I've put about about 5,000 miles on on them so far. Highway and backwoods. No issues.
Old 01-15-19, 03:36 PM
Arailt
Arailt's Avatar
looks dope!
Thanks! No rubbing on the calipers. There's plenty of room.
I think theses are knock-offs.
Old 02-10-19, 04:40 PM
MTD1
MTD1's Avatar
And they perform well. Had to get a little muddy today. I wish the video would upload!
Old 12-09-19, 08:05 AM
Chickem
Chickem's Avatar
That setup turned out awesome. Looking to match on my 2006 GX470 and want to make sure I have no rubbing or anything. Leaving stock, no lift or anything.
You mentioned you bought Toyota OEM TRD Pro SEMA Black rims. The only ones I see online come with a 4 offset. P# PTR2035110BK
Any advice on that?
Those tires you got, just verifying those are BFGoodrich 265/70/17 112/109S All Terrain T/A KO2?
While driving on the road have you gained any road noise or lost highway/city driving comfort with the more aggressive all terrain?
Any feedback would help.
Old 05-21-20, 11:31 AM
DasV8
DasV8's Avatar
First post here!
I'm very interested in these wheels in the dark gray for my 06 GX (silver) but finding the 17x8's difficult to track down and that ebay link from MTD1 is no longer working.
I recently installed 265/70/17 Duratrac tires on stock wheels. It looks like Arailt is running 17x7's but with 275/70/17 tires. I'm assuming my tires would work on the 17x7's as well, the Duratracs look a little 'bulgy' toward the bottom as is with the stock 17x7.5. Was hoping someone here is running the same combo and can confirm for a wheel/tire noobie
For reference - these are what I've stumbled on that appear to be legitimate: https://parts.olathetoyota.com/oem-p...l-ptr2035110gr
Old 05-21-20, 11:48 AM
Chickem
Chickem's Avatar
Originally Posted by DasV8
First post here!
Search for Gunmetal instead of gray.
https://www.ebay.com/itm/183935380867
Old 05-22-20, 11:57 AM
MDSteamer
MDSteamer's Avatar
Not a big fan of spacers myself. You did it right the 1st time!
Old 01-05-21, 07:28 AM
zmccoy
zmccoy's Avatar
Any advice on that?
Thinking about the same set up on mine. I don't want to modify the truck at all. But want the gunmetal wheels and bfg ko2 265/70/17. The offset is 4mm so do I need to lift? Does it rub?
Old 04-10-21, 09:28 AM
LXGX470
LXGX470's Avatar
@zmccoy im on the same path 4 months down the road on tire / wheel combo... wanting the same setup as you were looking for... any updates to help guide my way? thanks!!
Old 05-13-22, 08:41 AM
ALT164
1st Gear
ALT164's Avatar
Finally got time to have them installed. Baby got new shoes.
MTD1, did you use a spacer for the hub bore? Any shaking either way? The stock hub bore is 108 mm and the hub bore on the TRD rims with 0 offset is 110 mm. Looking at getting the TRD rims. With Continental Terrain Contact A/T 265/70R17. Not as aggressive as the KO2s but better than the Michelin Defenders we have had for years and have not been able to wear out.
Thanks in advance. Wheels/tires look great.
Best,
Mike
sgmstr
12-20-13 10:47 AM
IS_Sunny
Wheels, Tires & Brakes Forum
11-15-07 09:35 AM
lexlikenother
06-03-02 10:30 AM
Quick Reply: Need Wheel/Rim and Tire size advice GX470
