|| FIGS Engineering 3rd Gen IS Suspension and Brake Development Thread ||
Old Dec 22, 2014 | 02:33 PM
  #31
bayarea3is's Avatar
bayarea3is
is the custom design available to order?
thanks
Old Jan 4, 2015 | 10:47 AM
  #32
FIGS's Avatar
FIGS
The Maker
thanks
We are always driven by demand and pilot customers. So if you are ready we can start on it.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old May 4, 2015 | 12:51 AM
  #33
anthonys2r's Avatar
anthonys2r
http://shopfigs.com/v1/index.php?rou...product_id=197
Would this work to fix my camber in the front? 3IS IS350 F-Sport
Old Dec 10, 2015 | 02:43 PM
  #34
fryer's Avatar
fryer
Bump for below...I just bought the front lower arm bushings http://shopfigs.com/v1/index.php?rou...product_id=235 and will see how it does with the inner tire wear as I'm putting on brand new tires with these bushings running RSR down springs.
Old Dec 11, 2015 | 11:08 PM
  #35
sam430's Avatar
sam430
I wonder if it'll work...says fit 3gs... it may even fit 3is and 4gs.
Old Dec 14, 2015 | 04:08 PM
  #36
FIGS's Avatar
FIGS
The Maker
it should fit stamped steel arms, but the aluminum arms require a different bushing. Working on it.
Mike
__________________
Old Feb 24, 2016 | 06:51 PM
  #37
Redshift's Avatar
Redshift
Not lowering mines until i can get all the camber adjustment kits.
Old Jun 26, 2016 | 07:27 AM
  #38
Fcdrifter2's Avatar
Fcdrifter2
Need to do my soon, definitely going to look into these
Old Sep 30, 2017 | 06:41 PM
  #39
Sasnuke's Avatar
Sasnuke
Originally Posted by DEONDRE
Camber kit for 3gs/is, ordering end of next month. Will post once received and installed.
Which one is the camber kit for 3IS? Unless I'm missing an image, none of them are for 3IS except the LCA bushings.
Old Oct 1, 2017 | 09:57 AM
  #40
FIGS's Avatar
FIGS
The Maker
'This is our latest "Essential Kit" offering. We can also combine with swift lowering springs. The website is going through another update and things will be current early next week.
__________________
Old Nov 26, 2022 | 07:47 PM
  #41
Oneops's Avatar
Oneops
Just wanted to thank you guys! I’ve just done the Lca bushings. I was a bit worried about the wear at 10k I found in the frt. I have noticed it on the rear too I’ll look into a fix for that later. But the feeling driving the car now is a massive difference. It’s So goood! The steering felt so muted and laggy on input before. It’s a lot lighter feeling going lock to lock. Noticed it right away pulling out of the driveway. Just did a little test drive and it feels now how I’d expected it should have been. So responsive on turn in now. I’m not feeling like I’m having to add more input after I turn in like I was before. I turn and the car does it and feels instant. It’s fanfreakintastic plus I’ll get better wear now too hell yeah!
Bryan858
Suspension and Brakes
Apr 24, 2019 09:18 AM
gstreee
Apr 19, 2014 09:25 PM
Epik
Feb 14, 2010 09:48 AM
WickedLex
GS - 1st Gen (1993-1997)
Jul 16, 2008 11:24 AM
Epik
May 30, 2007 08:39 PM
