What did you do to your GS today?
Painter the calipers, painted the wheels with 5 coats of clear coat to top of the black, installed the Joe Z axle back, installed the Takeda intake and the carbon fiber lips -- ready for the car show tomorrow.
Chavez, looks awesome man, I have the same rear blacked out as you. The only thing I"m missing that I might do next after seeing yours is blacking out the exhaust. I have the CF inserts in the Lexus logo too which I really like.
Alright guys, I worked a bit on the wrapping today. Honestly this stuff is a huge pain to work with, it doesn't have very much flexability like a quality film. The upside is it actually looks like CF, I should do a side to side next to my CF spoiler in comparison. The knifeless tape is hard to use doing the trim on the inside without removing it since I can't lay the tape on a flat surface to start the cut, its a bit tricky to work with. So I ended up using a blade which I didn't want to do because I don't like risk cutting anything on the dash, but I think it was OK. In order to do the other panels in the center console I have to figure out how to remove that, also I need to so the rear doors. I got a bit faster at doing it after trial and error.
I had a huge roll of this stuff sitting in the garage, its pretty cheap stuff, I think it was only $20 shipped for a huge amount.
Spent hours cleaning up stone chips on the front end the original owner left me. Must have been a couple of hundred! Never used the product before, but Dr Color Chip works great. No, I'm not a salesman for them. I'll try to post pics soon.
https://www.drcolorchip.com/
Finished wrapping my backseat trim. I also had a broken wheel stud on my rear left I finally got around to replacing. Always used a impact wrench but mine is too powerful and saw the need to torque stuff down properly. My impact doesn't have a good gauge of what its set to just a slider and it goes all the way to 950lb/s. Got the broken lug replaced, and then installed my 20mm rear spacers. Running stock AWD suspension and stock 18s, I'm happy with how it turned out, I'm still debating if I want to do front spacers.
Edit: Have no idea why the upload it didn't fix image rotation, tilt your head if you want to see it haha.
Looks great!
