What did you do to your LS430 today?
Old Dec 14, 2016 | 11:00 PM
  #181
bmore430's Avatar
bmore430
Originally Posted by tallcaguy
Thanks. I have new Michelin Premier AS tires. Are these ok on a trip that may have a little snow (2-3" over mountain passes). I'd rather not get snows for just 1 trip. Doesn't really snow much in Sacramento CA
I have the same tires and they did great in up to 8 inches of snow. A few inches will be fine. Leave the traction control off as it only makes things worse when going up hills and it cuts power losing your momentum.
Old Dec 15, 2016 | 01:09 AM
  #182
Scootymad's Avatar
Scootymad
Originally Posted by bmore430
That 60 foot has room for improvement. I'd think with a stickier tire or different launch technique you could get that down to 2.0 to 2.1 and be in the mid 14s.
Potentially, the quoted 1/4 mile time is 14.8 ET, and I gave it every possible chance I could within my budget to hit that time. The smaller diameter rear tyres I had on there (205/55/16 Michelin somethings at 22psi) give it a slightly better run out of the hole, and I had a few solid launches where it hooked up damn well. I might try find some wider tyres but with a similar overall circumference and see how that goes. Not at all keen on trying out the 275's on my 20s though
Old Dec 16, 2016 | 05:38 PM
  #183
Johnhav430's Avatar
Johnhav430
I filled her up with 93 and logged the worst mpgs since getting the car. 14.1. OUCH. I always track avg mph as well, which was 17. This means almost all driving around town, etc.
Old Dec 17, 2016 | 02:35 AM
  #184
JffGRY706's Avatar
JffGRY706
threats to America today
1. BLM
2. ANTIFA
3. F.B.I.
4. the Chinese Communist Party
5. senile politicians
Old Dec 17, 2016 | 11:41 AM
  #185
Mobius1's Avatar
Mobius1
So far I have the following done, most recently [as of 30 minutes ago from writing] changing some of the exterior lights to LED's
2003 LS 430 Modern Luxury @ 70K miles
Important:
*Timing Belt and Water Pump and ancillaries TKT-021 ($450 Toyota dealership labor + $170 parts)
*Transmission and diff fluid machine flush and fill
*Power steering fluid flush and fill
*Brake fluid flush and fill
*Throttle body cleaning
*Kumho TA71 tires x4
*Oil / Filter change full synth
Unimportant:
*HID 3000K Fog Lights
*LED-white licence plate lights [ASIN B00YHYGGMG]
*LED-white rear back up lights [ASIN B00MC6RQAM]
*LED-amber front turn signal lights w/ load resistors [ASIN B019JDCO7K]
*LED-white trunk light [ASIN B00YHYGGMG]
*ViasTech MML-L1 thumbdrive audio player w/ 256gig drive
*Subwoofer replaced with 8" 16ohm Dayton SD215A-88 [ASIN B0045UY7M8]
*Refoamed surrounds of front door speakers
*12V-to-USB outlets and cables for 4 passengers
*Door LEXUS logo projecting LED puddle lights [ASIN B01DPBVEA0]
*Leather neck rests with Lexus logo stiching from China
*Some lame $4 LEXUS metal stickers on the side to make it look different [ASIN B01CE54HIY]
Still want to do:
*Replace trunk fluid struts
*Change the dash lights to LEDs. Or maybe simply remove the green cap color-filters. Not a fan of 90's-dashboard-green
*Replace the two orange lights that project down from the ceiling console to make them brighter.
[if money were no issue]
*Replace every part of the suspension / control arms
*Custom speakers, wiring, and amplifiers while keeping the looks as stock as possible and taking up no trunk space
*Double panned windows would be nice like on UL's
Old Dec 17, 2016 | 07:01 PM
  #186
911LE's Avatar
911LE
Hand washed and waxed today. Also redid my passenger front door lock actuator because it was making a clunk noise. Had it out, repaired, and back in in about 30 minutes.
Old Dec 28, 2016 | 06:47 PM
  #187
Scootymad's Avatar
Scootymad
I might do the rear brake pads today. Might being the operative word here. But the R/R is down on the steel now and its covering my brand new wheels in iron filings every time I drive it, and I want to drive it now so I probably should
Old Dec 28, 2016 | 07:36 PM
  #188
Tom57's Avatar
Tom57
On Black Onyx 2006 with 135K miles: Replaced idler pulley, installed 2016 Navigation disc, replaced windshield wipers (refills), and new front brake pads (rear pads tomorrow).
For my Mercury Metallic 2006, had new Michelin snow tires mounted to new chrome wheels.
Old Dec 28, 2016 | 08:16 PM
  #189
2KHarrier's Avatar
2KHarrier
Where did you get your disc?
Old Dec 28, 2016 | 08:20 PM
  #190
2KHarrier's Avatar
2KHarrier
I had the winter tires installed on the 2005 finally. Dealership installed them and also did a nice job cleaning the car for me. They gave me a NX200T to use while the LS was in the shop. Not bad, but after driving the LS, the ride of the NX gets a little tiring after a while.
Old Dec 28, 2016 | 10:38 PM
  #191
JffGRY706's Avatar
JffGRY706
check air in my tires today, 1st time since I bought them. low was 29.5 and high was 32. so off to the gas station where I set them to 36 all around. it was about 60 degrees outside. now it is night and 46. and it is 34 all around. a little more than I would like but I will wait a week or 2 to adjust them again. I guess this is normal, station is about a mile so tires should not have been hot at all when I set them.
Old Dec 29, 2016 | 05:03 AM
  #192
Johnhav430's Avatar
Johnhav430
I took the LS to Lowes to get some JB Weld (hey it works lol)
Checked and I put the snows on, Dec. 3., on both RWD cars. So I've been grinding the Xice's into the pavement for nearly 3 weeks. Well, maybe next year I'll wait until Dec. 15, and save 2 weeks wear!
btw here's how the OEM Lexus front rotors look after 2 mos. on the car. Note--the selling dealership put them on, and as I had requested, they even put antiseize on the hubs. Seriously, that's integrity!
Here's how OEM BMW rotors look after 10 mos. on the car. The antiseize is my doing. However, the originals, came right off with my fist. Note how BMW has no lugs, so without a locator bolt, it's really difficult to keep the rotor in its place.
Now to be fair, the Lexus have about 3k on them, the BMW about 1k. I am all about the hats. Look how badly aftermarkets rust (rotors are in spec and pads almost new from prev owner)
Old Dec 29, 2016 | 08:41 AM
  #193
Tom57's Avatar
Tom57
Here > http://navidvd.com/5-lexus . Authentic Nav disc, not a pirated, copyright infringement disc.
Old Dec 29, 2016 | 09:18 AM
  #194
Johnhav430's Avatar
Johnhav430
Why do you say no copyright infringement? They are selling discs for $45, seems implied...
edit site seems to have no email, no phone # (or maybe I missed it), whois shows the site is registered in LA
Old Jan 2, 2017 | 05:55 PM
  #195
Genofish's Avatar
Genofish
To my 2005 2005 Cyprus Pearl with Roderick Wheels
Rear Brakes
I added new Akebono front and rear ceramic brake pads, new drilled and slotted rotors, painted calipers and added Lexus logo stickers and new stop tech braided steel brake lines. Unfortunately the brakes are still soft and mushy. I did the same changes on my 2002 GS300 and the brakes were very firm. We bled them ourselves and then I had a shop bleed them and it was a little better.
