1992 SC300 5spd Chicken Coop Restore (tons pics)
Not original rear floor mats but close fit. Beige color before SEM
First coat of SEM
Second coat of SEM. Didnt take picture after brushing but they look alot better than picture
Factory light gray front floor mats. I wanted them to match the back ones and the darker trim plus I still had a little but of stain but after $8 of quarters at the pressure washer they came out pretty clean especially considering they are 22years old or I assume they are. The Lexus logo was faded out and I forgot to take a before picture but this was after three coats and just like the rear ones they looked alot better after brushing.
Car has started leaking really bad over the past few months to where I was having to put a quart of oil in every 500 miles.
Took to the mechanic today to figure out oil leak and valve cover gaskets where bad. There was so much oil the spark plugs where submerged in oil.
Had to replace the valve covers they were to corroded.
Picked up a set of used covers amazing the shape they are in compared to ones that came off.
Painted and ready to go back on car
So far everything Ive built has been on this wafer board table I threw together 22 years ago.
Decided to build me something I could roll around the garage and out in the driveway
Drop cord plugs into wall outlet and I wired in two outlets on each side that when the drop cord is plugged in the outlets are live.
Side of amp box cut and amp moved about four inches over
Area under where Im putting the passenger sub box is where the factory CD player was. I took all the brackets out because they kept rattling which left a huge hole under the sub enclosure so I layered the area in tinfoil and then filled it with liquid foam.
After it hardened sawed off to make even.
Trunk redone. Still need to recenter and screw down but looks a ton better and subs sound great now that both are enclosed and sealed. Subs are dual voice coil 4ohm. I should have gotten 2ohm since the amp is stable down to 2ohm but the amp is still putting out enough to shake the car.
Took out the liner and found another pile of leaves and trash.
Fortunate wiring harness hadnt been rubbed yet but you can see from the next picture it wasnt going to be long.
Rip in the liner right below the harness.
He started working on around 8pm and finished around 3am.
Wrapped with tape wire loom ordered
Got all four calipers painted. Will post pictures later.
This small piece was all that was left of the 4x8 sheet we started with on rebuilding the trunk. Probably 1/3 was mistakes etc.
Started rebuilding the doors. Was surprised at how good a shape the cables were in.
Backs of the doors like all SCs were starting to break apart etc. So tried to put some fiberglass and resin in all the spots.
Mixed up to much resin so spread it over almost the entire back of the doors.
Installed the 6.5 Cerwin Vegas in the front doors. Plastic cover on both doors was gone. Hope by replacing this will cure my leak on black floor boards.
Not really happy with the way the doors look but they are better than what we started with.
Proud of how hard my son worked/working on the car. From where we started to now has been an amazing change. Think once we get the paint on it will be better than when it came off the dealer lot.
