1998 - 2000 SC400 Differential Ratio
Old Apr 22, 2008 | 04:37 PM
Lextreme's Avatar
Lextreme
Default 1998 - 2000 SC400 Differential Ratio
Anyone know?
Old Apr 22, 2008 | 06:53 PM
Blizzy's Avatar
Blizzy
The 98-00 SC400 used the same 5AT that ran in the GS400. Both used a 3.7 rear end that is compatible with the same LSD units as the 92-97 SC rear ends.
I am presonally putting a TRD LSD onto a 98-00 SC400 rear end with a 3.27 ratio for the 5MT project I have in the works.
Old Apr 22, 2008 | 07:09 PM
ScottURnot's Avatar
ScottURnot
From: Sideways on the Yellow Brick Road! < Thats KS!
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, MT (3.133 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
Old Apr 22, 2008 | 07:28 PM
Lextreme's Avatar
Lextreme
Originally Posted by ScottURnot
92-97 SC300
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
Great info. Thanks Scott and Blizzy. As you guys know I am going for the TH400 and it only has 3 gears. The third gear is 1.0 so it is not freeway or gas friendly. Getting a lower ratio will help the RPM.
Old Apr 24, 2008 | 02:20 PM
Blizzy's Avatar
Blizzy
The 3.27 rear end from the 98-00 SC400 is 100% identical to the GS400 rear end. It is the lowest ratioed rear end you will find short of a 6MT Supra rear end that will require swapping out the companion flange and the axles.
If you are in need of one, Gazi (Member name: Aliga) sells them for $300 shipped...which is not a bad deal for something that is in relatively limited supply.
Old Apr 24, 2008 | 11:04 PM
Lextreme's Avatar
Lextreme
Thanks for the heads up.
xspsi6
Oct 11, 2022 03:02 PM
jonboyb
Mar 21, 2010 09:13 PM
Slow SC
Jul 11, 2006 08:22 AM
khark
SC400 / 300 Classifieds
Apr 13, 2006 06:24 PM
Hermosa
Jan 12, 2003 01:01 AM
