What should I pay for the 90k service?
The rub with supplying your own parts is that if something goes wrong after your service the installer can blame the parts that you supplied. It would be up to you to prove that his labor was at fault, and that would turn out to be time consuming, aggravating and stressful, and possibly expensive.
I just got mine done at a Toyota dealership - $725.00 out the door for timing belt, water pump (plus coolant), and serpentine belt. Was $499 just for timing belt work; asked about water-pump and they said it would be an extra $300 +$30 for coolant and $60 for serpentine belt.
He took off $100 for the water pump and I had a 10%coupon that got it done for about $725 out the door. I'm at 218k miles and hope to be good until 300k when I might upgrade to an LS460 by which time I hope it should be in my price range
if you have an '04- '06 with the lifetime transmission fluid and have not already done something you might consider it at this point. if you wait until 100,000 miles like my owners manual suggests it will almost always need some attention. drain and fill or full fluid replacement I am unsure, but begin to consider your long term options.
My Toyota dealership parts dept said they didn't have the parts for a LS430 (3UZ-FE), and so I bought the parts from Amazon. The parts are similar to a Toyota Tundra (2UZ-FE), I think.
Sent from an Android device using IB Automotive Group forum reader.
The main problem with service pricing is location. It seems in the south east areas things are just cheaper. So if a dealer sets a price nation wide, they goof themselves up in those states, as they are then not competitive.
I'm a DIY person, but still I think the best value is the Lexus dealer, in my area some time back I compared TB replacement prices, and all the independents where higher priced than the Lexus dealer, and did not include a loaner car. And that made the Lexus dealer shine.
Did they try to recommend replacing the idler, tensioner and thermostat as well?
I paid $918 at my local Toyota dealer. Can't remember all specifics, but believe it included belt (obviously), water pump, crank & cam seals, thermostat, idler, labor, and an oil change. Not as cheap as some others on here, but not as much as Lexus wanted either...
This is an old thread, but assuming the newest LS430 is over 13 years old, but most are over 14 (some were made in June 2006 but most by November 2005), imho it is not a good idea to have a Lexus dealer perform a major service any longer.
I think their is a mystique associated with having a car serviced at only a dealership, but I will stake my reputation on it. Indies do better work, they have to. One upset customer or one single case of wrongdoing they could be out of business. Not so with a dealership.
Take a brake fluid flush--dealer is not going around to all 4 corners and pushing new fluid out. At least not the one I went to. Would you do 1/4 of a job on your own car? No, you would not. And neither would an indie if he wants to stay in business. But a dealer tech is compensated by the job, and this is an extreme case of time is money. There's zero money to be made marking up a pint of brake fluid. There is on a brake job and/or a major service.
If you are looking to minimize maint cost but still take good care of the car avoid paying for the "services packs" that dealers push on customers (15k, 30k, 60k,90k, etc) For the most part these packaged services are a costly rip off. Instead perform service per the maintenance manual schedule in a la carte fashion. And do as much of small easy stuff (oil change, air filters, brakes, differential fluid change, etc) yourself and only use shop for more difficult or complex work (like TB/WP replacement). And even then buy the OEM Lexus parts yourself on line at a discount and then shop by phone for lowest labor only quote at respected shops/dealer that work on Lexus.
Actually luck is not required. Many but not all shops have no issue quoting labor rates to instal customer supplied parts. Very few want to work with unknown brand X parts. The key it is to explain up front that you have Toyota/Lexus OEM parts ready to be installed. I have rarely had a problem getting labor rates quoted over the phone when I explained I had brand new OEM parts that needed to be installed.
This can save serious cash because OEM parts can almost always be ordered on line at a significant discount.
Obviously a dealer or shop would prefer to charge customer full retail for the parts that they obtain wholesale in addition to profit on labor rate. Parts margin is gravy for them. But they will generally agree to work for labor rates which still provide them with a reasonable profit. I prefer that dealers and independent shops make the really big profits on someone else besides me.
I'll take you up on this in a while. I'm in MA. I'm at 195K, TB last done at 92K 6 years ago. Was thinking of doing it myself but the guidance of someone with experience would be huge.
