DMG Track build GS400 r154
The Three Types of Pipes
X-pipe: Mid-pipes built with a crossover, or "X" shaped design, purposely cross exhaust streams to even out flow and streamline exhaust gasses through the rest of the system. X-pipes are generally raspier and louder than H or Y-pipes and have been shown to provide slightly more power than their counterparts. You are likely to see most of the power gains higher in the rpm band with an X-pipe.H-Pipe: An H-pipe is better at balancing sound and produces a more consistent, classic muscle car growl. It does less than an X-pipe in the way of balancing exhaust gasses but still flows quite well. H-pipes maintain the back-pressure necessary for torque gains earlier in the rpm band, as opposed to the top-end power seen from an X-pipe.
Y-Pipe: A Y-pipe came standard on many late model V6 Mustangs and are sufficient for a mildly modded car. However, for those looking to install a power adder or make maximum horsepower, converting to a dual setup is ideal. The increased airflow from upgrading to an X or H setup gives you much more room to accommodate increases in horsepower and torque, relieving excessive back-pressure.
Also, I do more road racing with the vehicle. So i am usually in the upper range of the rpms.
Will_GS400 (09-25-18)
