430 really turtle slow from take off???
Old May 18, 2022 | 10:40 AM
Ripple24's Avatar
Ripple24
2nd gear
Thank you for this question and the answers. I reset the ECU and what a difference!! Cheers!
Old May 18, 2022 | 11:13 AM
tiglesias's Avatar
tiglesias
Congrats Rip. I believe many SC430 owners overlook this advice. In my case, instant throttle response and transmission down shifts return RIGHT after completing the ECU RESET. Pass it on !!!
Old May 18, 2022 | 11:52 AM
LatinLS430's Avatar
LatinLS430
Do you guys know if the ECU reset is the same for the LS430?
Old May 18, 2022 | 05:14 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
it might be…give it a try.
i certainly would do it.
Old May 19, 2022 | 06:02 AM
Hope4lexus's Avatar
Hope4lexus
The reset worked for me for a few days then lag returned, I will reset again and look at sprint booster
Old May 19, 2022 | 10:26 AM
Harold57's Avatar
Harold57
In agreement with BGW. I'd be surprised if the ECU is different than the LS430. They share many parts, including the engine, so I suspect that they have the same ECU, besides, Lexus should want to have the same commands fleet-wide to make it easier on their mechanics.
Old May 19, 2022 | 04:25 PM
Cavedog's Avatar
Cavedog
Until you get the original problem fixed, any kind of throttle inhanser will be useless. When you get the original problem fixed, you will most likely not want a throttle inhanser.
Old May 20, 2022 | 04:38 AM
Hope4lexus's Avatar
Hope4lexus
Wait. I understand the throttle enhancer as the fix, it removes that initial lag. If not then I am not sure how to correct the issue. I was hopeful that plug and play device would cure the problem.
Old May 21, 2022 | 01:19 AM
GmanSC's Avatar
GmanSC
You could have a MAF problem. Check all vacuum hoses.
Old May 21, 2022 | 06:48 AM
Badhobz's Avatar
Badhobz
hope4 did you get a guy to look over the whole car yet ? Do that first. Pretty sure it’s a mechanical issue you have. I don’t ever recall our cars not being super responsive.
Old May 21, 2022 | 09:40 PM
Studog's Avatar
Studog
Get the ECU checked. If just a couple of caps have leaked then there will be lag. Anyway, that has been my experience.
Old May 23, 2022 | 12:08 PM
digitatc's Avatar
digitatc
Drive with c-gate shifting to see if you have any lag. It should be a blast to drive like that. If you just put it into Drive and expect it to jump, you wont get it.
Unless.
You remap your ECU. I think it cost $300 for the fee & the cost of the ECU. I would suggest get spare ECU for this, and keep the original just in case you need to do smog check every other year like in CA.
Old Jun 6, 2022 | 11:29 AM
LatinLS430's Avatar
LatinLS430
I did the reset over the weekend for my LS and I do feel an improvement in the throttle response.
Old Jun 6, 2022 | 12:09 PM
khuong's Avatar
khuong
sprint booster I see is only up to 2007… I have a 2008
Old Dec 9, 2022 | 02:43 PM
JohnSenior's Avatar
JohnSenior
9th Gear
Just did the reset! It's like I have a new car!
THANKS
