Help with navigation diagnostoc
Old Apr 24, 2022 | 11:25 PM
malema's Avatar
malema
Default Help with navigation diagnostoc
Hi all.
Hope everyone is having a good weekend. I have a navtool video interface with some other setups feeding through it in my sc430.
last week when starting the car, navigation screen wouldn’t turn on. It would open and tilt and show the Lexus logo but then it would immediately go black. In the past if this happened, I’d press the “map” button, everything would work again. This time, nothing would happen when pressing the destination/map buttons (no sound would beep either). Only info/brightness button would turn the screen on but then most functions would be disabled (no navigation etc), No other button or parts of the system would work. I kept restarting the car and pressing the map button until suddenly it beeped and everything started working again. This happened twice so I know something is failing and needs repair.
would y’all think this is a issue with the navigation drive? Navtool interface? Screen itself?
TIA for the help
Old Apr 25, 2022 | 08:27 AM
GmanSC's Avatar
GmanSC
Easiest thing to do is pop the NAV disk out and reinsert. Second, replace the DVD. It’s in the trunk.
Old Apr 25, 2022 | 09:51 AM
DshngDaryl's Avatar
DshngDaryl
It sounds like the screen is good since you can read the settings the screen puts out (As compared to the settings the nav settings put out)
Info/Brightness is not tied to the nav system.
Old Apr 26, 2022 | 11:37 AM
SeaStories's Avatar
SeaStories
I had a similar issue with my navigation screen when I had a VAIS Technology aux input adapter. I recommend disconnecting the Navtool and see if it solves your problem.
SeaStories
Ire83
ES - 7th Gen (2019-2025)
Dec 2, 2020 02:51 PM
Wormsucks
Jun 29, 2017 04:39 PM
benz23
Jun 20, 2008 10:38 AM
Kyoto
Mar 7, 2005 08:55 PM
