Does this thing work?
Old Jun 16, 2020 | 10:41 AM
GmanSC's Avatar
GmanSC
Default Does this thing work?
Too good to be true. Headlights restoration. Just spray on and wife off?
https://bit.ly/3fqivsB
Old Jun 16, 2020 | 11:07 AM
MrIanB's Avatar
MrIanB
Old Jun 16, 2020 | 11:52 AM
DJWLDW's Avatar
DJWLDW
GmanSC
Let us know if you try it
Dennis
Old Jun 16, 2020 | 03:33 PM
Wilson2000's Avatar
Wilson2000
It's probably just a clear coat. I doubt it would come out well without a lot of prep work.
If you sanded down a plastic headlight lens with fine-grit sandpaper, and sprayed it with any clear coat, it would bring back the lens to being somewhat clear. I doubt this product works better than any can of clear coat.
The beauty of the headlight lens kits is they provide varying degrees of sand paper so you can remove varying degrees of damaged to the outer layer of plastic. Then, you use polishing agents to remove the fine, invisible scratching left behind from the sanding. The final step is clear coating the lens.
Many feel the work involved in doing this properly isn't worth the trouble and prefer to replace the headlights or headlight lenses.
Old Jun 16, 2020 | 03:35 PM
GmanSC's Avatar
GmanSC
Dennis,
My headlights are crystal clear so this product won’t do any good.
Old Jun 16, 2020 | 03:50 PM
DJWLDW's Avatar
DJWLDW
GmanSC
As are mine.
Dennis
Old Jun 16, 2020 | 03:51 PM
daddiojigg's Avatar
daddiojigg
Sounds expensive!
Old Jun 17, 2020 | 12:51 PM
mandyfig's Avatar
mandyfig
Not worth trying, too good to be true.
Jafd20
Jan 28, 2019 07:29 AM
jromanooo
HS 250h Model (2010-2012)
Apr 4, 2017 04:28 PM
ZachAttack
Sep 8, 2010 07:23 PM
ace263
IS - 1st Gen (2001-2005)
Jun 19, 2008 05:07 PM
SC400TT
May 17, 2006 06:00 AM
