Radio Question
Is there any way to set the radio on the FM setting without raising the antenna? I have bought a ROAV Smart Car Charger F2 which streams music from my ipad thru the SC sound system..
Dennis
Dennis
I don't believe there is a fuse for the antenna. You would need to physically unplug the power to the motor. I use a Bluetooth module that interacts via the disk button for streaming but I have also thought about disconnecting mine.
Even though I dont use FM/AM radio, I like the solution from @leexed.
I'm pretty sure when you play cd/tape antennae doesn't go up.
Harold
My Antennae does not go up when I use my CD player which works great filled with 6 cd's. So someone must have turned it off. Now with the Bluetooth FM device I will just use the iPad for my music not cd's.
Dennis
Dennis
