TPMS: Favorite Subject - Can't disable it
Old 04-28-19, 07:08 AM
GmanSC
GmanSC's Avatar
Originally Posted by Harold57
Wow, I totally missed that.
TSB is probably Technical Service Bulletin.
Or, TSB= Tire Sensor Baterry ?
Old 04-28-19, 07:22 AM
Bgw70
Bgw70's Avatar
Harold is correct...
Old 04-29-19, 11:01 AM
DshngDaryl
DshngDaryl's Avatar
Has anyone ever tried to set the threshold of lower limit to -1 after taking the sensors out?
I wonder if that would shut off the light.
But on second thought, if the ecu isn't reading any pressure sensors, it wouldn't read any pressure.
Old 06-17-19, 09:11 AM
GmanSC
GmanSC's Avatar
The warning light is still off. I hooked up Techstream last night and it showed three out of four sensor are not communicating with the ECU. The voltages are good though. What I don't understand is the warning light was ON until the battery was discharged/recharged and now the warning light is off? VitiBob, can you explain? Wonder when the light turns on again?
So, guys, you CAN disable the warning light if you have dead sensors. As you can see from the Techstream table, I have three dead sensors (notice the temp in the dead sensors) and don't have warning light.
Old 06-23-19, 11:51 AM
jjefferjo
jjefferjo's Avatar
I printed off the instructions found on this forum and had my mechanic disable, no problem, had new tires installed about 4 months later - No problem
Old 06-23-19, 11:58 AM
GmanSC
GmanSC's Avatar
The disconnect connectors method won't work on 06+ SC.
matts6887
01-17-21 08:10 PM
maarp
09-11-18 03:57 AM
mjclsi
GX - 1st Gen (2004-2009)
20
08-02-17 12:58 PM
MyIS350G
09-19-10 01:38 AM
Habious
06-30-08 04:54 PM
Quick Reply: TPMS: Favorite Subject - Can't disable it
