navigation door AND Axxess Steering Wheel
Hey team, good day to all
i have SC430 2002 I love this car i have problem in navigation door not open in CLIMATE CONTROL All the buttons work i also checked fuse in fuse box passengers side all ok i checked Navigation door motor in Manual this work good Any idea pls and also i have Axxess Steering Wheel Control Interface ASWC-TOY-LEX I installed it the right way but it does steering wheel controls not work Any idea pls thanks |
Originally Posted by a61bk
(Post 10408816)
i have SC430 2002 I love this car i have problem in navigation door not open in CLIMATE CONTROL All the buttons work https://youtu.be/VNlTEV_2BQ8 i also checked fuse in fuse box passengers side all ok i checked Navigation door motor in Manual this work good https://youtu.be/zUPjF1elXMw Any idea pls The Climate control has multiple wire harnesses that go to it. It is possible the one that controls the door is loose. It is also possible the motor is bad. If you want to check for a loose harness, you can watch this video on how to get to it |
(Post 10408816)
The nav system is connected through the factory radio for power. It appears that you have an aftermarket radio hence the reason the nav door no longer works. Just use the nav in the aftermarket deck or unplug every thing put the factory deck back in open the door the uninstall and leave it open, Unless you have the schematics to find the exact wires on the harness to pull power from.
