Drivers side mirror issue
Old 09-20-18, 10:47 AM
Harold57
Harold57's Avatar
You can pick them up on the used market for between $100 & $200.
Old 09-20-18, 02:55 PM
GmanSC
GmanSC's Avatar
Originally Posted by gbdad
Dog gonit...wd40 didn't work...I can't even hear the mirror motor for up down, only left to right, anymore suggestions?
Why don’t you just remove the mirror so you can see what’s going on in side? The removal procedure is in the link of Pogman ‘s post. If you’re lucky, may be it’s just a jammed gear. You can replace the motor if needed.
Old 09-20-18, 03:23 PM
gbdad
gbdad's Avatar
I just don't want to get it apart and have no new motor to put in it. Where can I get one before I start and what is it called? Thanks bud!
Old 09-20-18, 10:44 PM
GmanSC
GmanSC's Avatar
Read post #12 from BGW for motor part Read Pogman link for motor replacement.
Old 09-21-18, 09:41 AM
GmanSC
GmanSC's Avatar
The worm gears in the mirror are soft plastic parts and very easy worn out. Save yourself some trouble down the road, avoid unnecessary adjustments. Leave the selector switch in the neutral position to turn off the auto tilt feature.
JDaveSC430 (09-21-18)
Old 09-21-18, 05:44 PM
Harold57
Harold57's Avatar
I kind of have a different viewpoint on the auto tilt.
I used to run it all the time but saw the wisdom in the statement that you made above and also JohnnyCake when he stated something similar several years ago. However, I found that when I didn't run auto tile, my mirror started locking up and would need assistance to move. After I got it lubricated and moving again, I turned my auto tilt back on. It hasn't given me any problems ever since.
I tried popping my mirror off and was unsuccessful. I was also concerned that I'd break the mirror in the process and then really be out of luck.
Old 09-21-18, 11:34 PM
GmanSC
GmanSC's Avatar
I have not popped my Lexus mirror but I have popped my Corollar's. Just pulled it right off. When you replace it back, just make sure the tabs are aligned plus a good tap and it good to go.
Old 09-23-18, 09:12 AM
texsexlex
texsexlex's Avatar
Originally Posted by njsteve
I had the same issue with my passenger side
i read a post where you just manually move the mirror u/d and sideways for a few times
it work for me
but I might use a spray to keep it working
...hey njsteve this is the procedure I used, along with the spray that I suggested to Harold. After you initially get them to unstick, they should be good to go. The lubricant is more preventive for the future & I do them about every 3/4 months
Old 09-23-18, 02:26 PM
Harold57
Harold57's Avatar
Mine would either stop moving altogether or would be kind of jerky but not really move. So I sprayed it and just kept at it, especially when going over bumps to help urge it along. It eventually started moving more until it was to the point of being completely freed up again.
matts6887
07-24-18 08:40 PM
mwswindell
GX - 1st Gen (2004-2009)
07-04-17 07:20 AM
Runamok81
04-08-17 02:15 PM
IsFast3r
IS F (2008-2014)
12-07-12 08:40 PM
Quick Reply: Drivers side mirror issue
