Panel lights won’t turn off.
I own 2002 Lexus SC 430. By accident I locked my keys in the car while the car was running. When my friend got the door unlock the security system went off. I turned the car off and the security system and everything seemed fine. About 10 minutes later I restarted the car and my panel lights i.e. Vsc light, vsc off light, brake light, abs light and check engine light. I have absolutely no use of these items. on and I cannot get them to turn off. I tried disconnecting the battery for 30 minutes but that did not change anything. I would greatly appreciate any help someone might give me. Thank you in advance.
I forgot to mention that I have no availability to use my abs, vcs, Vsc, check engine light is on, etc. Is there anything that you can add to your last replay?
Landman, this is very common problem on Pre 06 SC. If you can’t build the simple tool or shorting the two pins with the paper clip then the only thing for you is take your SC to the mechanic or dealer so they can reset it for you. Let us know how much they charge for this job.
Or did the problem come back?
If your CHECK ENGINE LIGHT is on, you have a physical problem problem that needs to be addressed.
If just the other lights are on, then the paperclip trick might work
