02 sensor help
Old Oct 14, 2017 | 02:17 PM
jazzyunit's Avatar
jazzyunit
Default 02 sensor help
I have a 2003 SC 430, previous owner hollowed out the Catalytic converter‘s and put in a cat back magnflow exhaust system. I continually get P0153 and P0156. I understand it’s the malfunction of the O2 sensors but can anyone tell me how to trick these out to clear for New York State inspection? I really really do not want to replace both Cadillac converter‘s. Thank you any help is severely appreciated !
Old Oct 14, 2017 | 11:57 PM
GmanSC's Avatar
GmanSC
Try this, it might work. Clear the engine check by disconnecting the battery or use Techstream. Run for about 30 miles then take to the smog check .
Good luck.
Old Oct 15, 2017 | 05:08 AM
jazzyunit's Avatar
jazzyunit
I have a hand held scanner, so I clear CEL through that, do you think disconnecting the battery will be better to try and pass? I need my car to pass New York State inspection by tomorrow... so I need help... thanks
Old Oct 15, 2017 | 09:10 AM
GmanSC's Avatar
GmanSC
Just clear the code, run the car for 10-20 miles, then smog check.
Old Oct 15, 2017 | 10:54 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
if the car does not complete all system check before the inspection they will either tell you to go drive more or fail you.
check out this thread
https://www.clublexus.com/forums/sc4...0153-help.html
did you read the meaning of each code?
if not, google them.
Old Oct 15, 2017 | 12:35 PM
jazzyunit's Avatar
jazzyunit
I have tried the disconnecting of the battery, cleared cel but codes still say p0136 and p0156. Says CKT malfunction? Tried spark plug non foulers, cel continues to appear. Does anyone know how to fix this? Is it an electrical issue or do you think the 02 sensors are bad?
Thanks
Old Oct 15, 2017 | 01:21 PM
jazzyunit's Avatar
jazzyunit
Yes I read it, I have an appointment with my mechanic in the morning to check to connectors and the wiring. Thanks for all your help
Old Oct 15, 2017 | 01:28 PM
Harold57's Avatar
Harold57
Good luck and BTW, welcome to the forum.
Old Oct 15, 2017 | 04:07 PM
GmanSC's Avatar
GmanSC
My 07 Corolla had the same problem. I just cleared the check engine light, drove 20 miles then smog check. It passed the test. The check engine came back next day. In fact, it's still on now, but who cares. I will do the same thing next smog check.
Your car will fail the test if check engine is lit but your sensor won't, at least in California.
Old Oct 16, 2017 | 11:29 AM
DshngDaryl's Avatar
DshngDaryl
Part of me thinks your rear O2's are disconnected BUT once you get them connected you are going to get a Catalytic Convertor inefficiency code.
I think you will probably end up replacing your cats.
Old Oct 17, 2017 | 02:30 PM
Jabberwock's Avatar
Jabberwock
My apology in advance for being blunt but please get your car repaired rather than trying to get around the testing. Get your car repaired so that your car can legally pass the smog test portion of your state's car inspection. They test for smog and want folks to repair their cars that are not in smog compliance for a very good reason. If everyone cheated on the testing instead of getting their cars repaired and in smog compliance the air would be pretty bad to breath.
Old Oct 27, 2017 | 02:18 PM
DshngDaryl's Avatar
DshngDaryl
So Jazzy, what did the mechanic end up saying? Was it an easy fix?
hamooduae
IS F (2008-2014)
Sep 28, 2019 10:36 AM
S1aristo
Jan 22, 2016 02:30 PM
Lavrishevo
20
Aug 24, 2012 10:36 PM
LudeNsoL
Jan 21, 2010 11:41 AM
/Aerostar\
Apr 15, 2004 07:19 PM
