Techstream Cable Firmware Software Version Help
Old Jan 29, 2018 | 01:51 PM
  #61
Bgw70's Avatar
Bgw70
Veteran: Air Force
Originally Posted by Harold57
While I still haven't gotten the software up and running (next step is to try the link otmike provided), I have made an adapter that I've mentioned in the past to prevent the Techstream from creating an error. I hooked up the 5 pins that Retroplay were needed (4,5,7,15,16) and plan to use it whenever I get the Techstream up and running. I will add a switch in it later (I couldn't find any appropriate around the house to use) to be able to kill the errors when they do show up (shorting 4 & 14).
Harold, did you have any luck downloading and installing TechStream?
also, let me know if you need help with the VSC reset plug.
Old Jan 29, 2018 | 02:02 PM
  #62
DshngDaryl's Avatar
DshngDaryl
When I made my reset tool, I started out soldering the pins together with a foot of wire. When it didn't work, I followed your picture and connected those two holes with a small piece of wire (maybe 1/8 or 3/16 of an inch) and covered it with solder. It was MUCH easier than soldering a wire from the one pin to the other.
Old Jan 29, 2018 | 02:04 PM
  #63
DshngDaryl's Avatar
DshngDaryl
Harold,
You can try installing the software on the disc you have. That should load techstream and the driver for the cable you own. From there you can update to the newer version.
By doing it this way, you can make sure everything works at least once.
Old Jan 29, 2018 | 05:01 PM
  #64
Bgw70's Avatar
Bgw70
Veteran: Air Force
so glad you were able make it work!
the tool makes it so easy to reset the VSC error...and I can plug it in while I am in the drivers seat. No climbing under the dash.
Old Jan 30, 2018 | 10:41 AM
  #65
Harold57's Avatar
Harold57
I haven't had time to get back to it yet. My laptop is so slow that I wasn't able to try very many things on it yet.
I have my adapter cable built, I just need to add a switch to it so I can enable or disable the reset portion as needed. The wires to connect it to a switch are already in it. So I just need to buy the switch and add it.
Old Jan 30, 2018 | 12:25 PM
  #66
Bgw70's Avatar
Bgw70
Veteran: Air Force
are you connecting a switch to pins 4&14?
that is a good idea!
Old Jan 30, 2018 | 05:16 PM
  #67
Harold57's Avatar
Harold57
Yes. I had hoped that my picture would show my wiring on the piece of paper but it looks washed out. So I connected 4, 5, 7, 15 & 16 together and brought wires out from 4 & 14 to either short out or use a switch to short them out on demand.
Old Jun 2, 2025 | 09:35 AM
  #68
Vanmax1313's Avatar
Vanmax1313
Had anyone got it to work on Windows 11. I bought a Toyota specific VX DIAG works on a Toyota but not on my Lexus SC430
Old Jun 2, 2025 | 11:37 AM
  #69
iolmaster's Avatar
iolmaster
Yes, you have to install Techstream in a virtual machine on Windows 11. It does work.
Old Jun 2, 2025 | 02:25 PM
  #70
doobs's Avatar
doobs
I've got it running on a Linux box (Pop!_OS COSMIC Alpha 7) in a VM.
Works great. Used it last Monday to reset my TPMS .
D1ESEL
Nov 10, 2015 05:49 PM
LS4thirsty
Apr 14, 2014 04:06 PM
edmondt
Aug 1, 2011 06:51 AM
blizz
Performance
Mar 7, 2004 08:14 PM
