low profile tires?
low profile tires?
Does anyone know if the SC430 can take regular standard profile tires? I went to NTB and they said that only the LOW profile tires will fit this vehicle. I prefer the standard tire if it will work. Please let me know if you are aware of any tire brand that is NOT low profile that I should consider.
Thanks very much for your advice!
What size rims are you running? If you have the stock 18 inch rims, you should be able to use standard tires with no problem. If you go up to 19 or 20 in tires, you will probably have to run low profile tires.
If you aren't sure what tire size you have, look at the side of your tire for a number that looks something like this. 245/40/R18
The number after the R is the RIM size.
http://www.justtires.com/content/con...eName=TireSize
Tire Size Calculator
https://tiresize.com/calculator/
Bobcat
05-10-01 03:00 PM
