Headlamp vertical adjustment - higher SC
Anybody who has tried adjusting their headlamps to go up a bit? Mine seats low. I have a hard time seeing the road ahead.
I have researched and could not find information on how to adjust the headlamps (other than the IS section).
Any information leading to the resolution of this issue is appreciated.
I think there are several threads that talked about adjusting lowbeam(main headlamp) aim on SC430 on this forum. I have done it myself (yes, to raise the beam angle a little bit) and its quite easy. The process is described in the owner's manual---clockwise to lower the beam and CC to raise the beam. It takes about ten turns to move about one degree, so it takes a bit patience.
Thanks, time to open up the manual again...
