Is your exhaust brackets rusty ?
Old 05-27-17, 07:59 PM
jonas's RX
jonas's RX's Avatar
Default Is your exhaust brackets rusty ?
I was getting an oil change and I notice my exhaust are rusty . Does anyone see with your SC ? Everything else is tight other than the two brackets
Old 05-27-17, 08:00 PM
jonas's RX
jonas's RX's Avatar
Is your exhaust brackets rusty ? Weird
everything else look good other than the teo brackets
Old 05-28-17, 09:46 AM
texsexlex
texsexlex's Avatar
....mine are also, but don't look quite as bad as those in the pic. I think one of the reasons it might be this way, is because the brackets & the exhaust are made of different materials
Old 05-28-17, 11:19 AM
Bgw70
Bgw70's Avatar
I know now what you mean about the rust! Seems to be typical on certain exhaust components
Old 05-28-17, 11:22 AM
jonas's RX
jonas's RX's Avatar
BGW70
wow my 02 is exactly like yours.
everything else in the undercarriage is rust free but
the two brackets. I wondered if this was a defect ?
Old 05-28-17, 02:25 PM
kevin3344
kevin3344's Avatar
My GS400 has the same discoloration and has lived it's whole life in NC. My SC430 is from Florida. I don't think it's anything to worry about.
Here is the exhaust on my SC430...
And my GS400...
Old 05-29-17, 01:58 PM
jonas's RX
jonas's RX's Avatar
Has anyone try use vinger and a wire brush to clean all that rustoff the exgaust bracket ?
I wondered if the rust will eventually eat through the brackets,?
rust on the brackets cannot be good for the brackets that hold the exhaust muffler together
Old 05-29-17, 03:00 PM
OBP
OBP's Avatar
Yeah I have the same issue and pretty close to the pics posted here so I will not post a pic. At some point I guess this can deteriorate to where you need to replace but I guess then I will get an after market exhaust system replacement. I expect I will be alright in the short term though.
Old 05-29-17, 03:02 PM
kevin3344
kevin3344's Avatar
I've noticed the discoloration for several years on my GS, but I don't think it's anything to worry about. I haven't had any problems out of the exhaust at all. I just think the discoloration happens over time. Then again, if after 17 years something happens I will just replace the exhaust! lol. But so far so good.
Old 05-29-17, 05:26 PM
jonas's RX
jonas's RX's Avatar
Guys if the exhaust is still good, I think a wire brush and
some vinegar will get the surface rust off
there is no point in waiting till the rust penetrate all the way
through the muffler .
has anyone try to use a wire brush and vinegar to just
clean the brackets ?
if I was mechanically incline, I would do it myself
Old 05-29-17, 05:29 PM
jonas's RX
jonas's RX's Avatar
If you look at BGW70 new muffler setup it looks like
he did change everything out with his muffler system but
the muffler where the brackets are rusted
i as sure his muffler shop saw the rust but I wondered
why he didn't get them to clean or repair the brackets ?
Old 05-29-17, 05:53 PM
MJG87
MJG87's Avatar
Pretty typical for exhausts to rust around the Flanges (not brackets) especially if you live somewhere with icy roads that get salted. It's not really something to worry about unless it is particularly bad, hit them with a wire brush to clean them up a bit. Flanges are normally very thick and hold up to the rust okay. The only real drama is removing bolts from them. Clean the rust off with a brush and inspect the welds, id the rust isn't eating into them, or eating into the pipes close to the flange, don't stress, just keep an eye on it every once in a while.
Old 05-29-17, 06:29 PM
Coleroad
Coleroad's Avatar
If you're talking about the flanges from the mid pipes to the muffler. Those flanges are thick . It would take a whole lot more years to rust through them. 03 here and they aren't that bad.
Old 05-29-17, 09:36 PM
jonas's RX
jonas's RX's Avatar
It looks like it is not a climate issue but those 2 brackets tend to get
rusty. As long as it does not break off, then we are good.
it sounds like everyone so far who has the older SC 02-05
has this part that are rusty
i wonder if the newer SC have the same rust bracket issues
Old 05-29-17, 10:14 PM
MJG87
MJG87's Avatar
Have seen it on every exhaust I have ever looked at on any vehicle, just a matter of time.
Quick Reply: Is your exhaust brackets rusty ?
