Another radio door cover stuck open
Old 04-20-17, 02:31 PM
kevin3344
kevin3344's Avatar
Default Another radio door cover stuck open
I know this is a common problem on the SC430s and would like to take a shot at fixing it on my 2002. So far these are the things I've narrowed down to as the problem:
1. Switch - glows green (seems ok) but I ordered another switch on eBay just in case that was confirmed working. Both only work intermittently so I don't think it's this.
2. Motor - the door opens smoothly when it works.
3. Control unit - my thought is it's probably this.
Does anyone know if you can order the control unit that sits on top of the Mark Levinson receiver? I saw one on eBay I could purchase as well. The door seems like it's running smoothly (not out of alignment) and works maybe 1 every 20 times I click the button. Thanks!
Edited to add: I found the part number on MyLParts.com it's 55406-24010 and the cost is $1,068.23. I think I will stick with eBay
Old 04-20-17, 06:24 PM
Harold57
Harold57's Avatar
What is the failure mode (other than it intermittently not opening)? Does it make any noises or any other unusual things?
Old 04-21-17, 05:11 AM
kevin3344
kevin3344's Avatar
I'll take a look when I get the car back from service today. I was looking at the Lexus owner records from a couple years ago and it said the previous owner needed to replace the entire assembly.
I did find just the control unit on eBay for $179....as opposed to the entire Mark Levinson radio (that includes the door mechanism). I think I can swap out the light colored wood door for mine with a couple of screws.
Old 04-21-17, 06:27 AM
Bgw70
Bgw70's Avatar
Here is my thread on the servo motor.
https://www.clublexus.com/forums/sc4...oor-motor.html
Old 04-21-17, 07:10 AM
kevin3344
kevin3344's Avatar
Originally Posted by Bgw70
I tried to repair mine, swapped the door servo motor but would only close after that...just bit the bullet and found a salvage yard scene assembly and replaced the whole thing.
Do you think I should buy the whole unit on eBay, and just swap out the wood door? I have the dark wood interior. I think it would work!
Old 04-21-17, 10:35 AM
jzdulexus
jzdulexus's Avatar
The whole working unit for $179 instead of $1079 (from Lexus part) is pretty good!
Old 04-21-17, 12:49 PM
Bgw70
Bgw70's Avatar
that is what I did... as you said before, the cover is an easy swap and a salvage yard will usually stand behind their products! I purchased many...all four HVAC vents, master cylinder, video screen etc. everything worked as advertised and reasonable prices.
Old 04-22-17, 03:24 AM
Bgw70
Bgw70's Avatar
Kevin, have you removed the unit from the dash to take a look at everything?
my post above had to do with the Nav screen replacement but I would guess to say the radio unit uses the same motor.
i looked up the unit on eBay and I would pull the unit, check it on my workbench and possibly look at replacing the little servo motor. Can you solder?
the motors are $2 ea and I purchased three Nav Door motors for about $8 shipped.
if your not good at doing that stuff, I would recommend you purchase the assembly for $179, but you need to be sure it will correct the issue.
Old 04-23-17, 11:23 PM
ShawnOk
ShawnOk's Avatar
if it comes to it, the front wood panel can be replaced. Only two small screws. I've taken mine off to vinyl wrap it.
Old 04-24-17, 05:13 AM
kevin3344
kevin3344's Avatar
Great, thanks. I've gotten the center console out and from what I've read the a/c controls come straight out as well? If so, I'll order the part today and replace the door. Thanks!
Old 04-24-17, 09:31 AM
jzdulexus
jzdulexus's Avatar
Yes, the AC control comes out with some pull. There are youtube videos showing the process, a bit daunting if you have never done it, but quite doable.
Old 04-24-17, 10:57 AM
mandyfig
mandyfig's Avatar
Yup there's 1 good DIY on on utube...
Old 04-24-17, 01:06 PM
kevin3344
kevin3344's Avatar
Great I'll check it out thanks!
Old 04-24-17, 10:16 PM
texsexlex
texsexlex's Avatar
....just be very careful of where you're grabbing & pulling it. I didn't watch the youtube video & actually pulled the face of the a/c control panel, off the unit.....needless to say, it was an expensive lesson...lol
Old 04-25-17, 08:44 AM
kevin3344
kevin3344's Avatar
Thanks! I was just about to do that until I saw the video!!
Quick Reply: Another radio door cover stuck open
