Where are the Groubd / Grounding points on the SC430?
Where are the Ground / Grounding points on the SC430?
Many of our posts recommend you "check the ground" as in the grounding points. Where are those located?
Good Infos. Thanks.
Wow Nic,
That's fantastic. THANKS!
I never realized there were so many grounding points.
Grounding area pics..
Under Steering Wheel
Behind Drivers kick panel
Hi,
I purchased a wifi flex cable camera to photo to do some electrical inspections, camera not bad, trick is to keep still.
1-Ground with White connector is the ground left of Steering behind left side driver kick panel.
2-Other image with Red component is located under the Steering Wheel Shaft and that is a another ground location.
B-
tuterz
03-06-15 11:57 AM
05SC430PB
07-07-12 10:56 AM
