Upgrade nav disk?
Old Oct 22, 2013 | 08:01 PM
indawire's Avatar
indawire
Default Upgrade nav disk?
My dealer tells me the new upgraded nav disk they just got in will work in my '02 sc which has the original disk in it. Does anyone have experience with this or have done it They want $200 for it, any better $ out there? Thanks.
Old Oct 23, 2013 | 05:18 AM
FlopTop04's Avatar
FlopTop04
If you still have the original hardware, your system is the Gen 2/3 variety. Lexus comes out with a new
disc every year. Typically it's just updated maps ( sometimes it is updates to the operating system ).
If you use the navigation system and have had issues due to new roads and other highway changes,
then an update might be a good idea. If you are still using the 2002 disc, your maps are 12 years out
of date. One thing you will loose is the "Acknowledgment Hack". However, I have found most dealers
will install the new disc for around $169. It is a very DIY upgrade if you can find the correct disc for
your system online.
Old Oct 23, 2013 | 06:10 AM
chrisv78's Avatar
chrisv78
Be careful of online "bargains" though. If you see an offer that is too good to be true, it may be an illegitimate copy, which would be a violation of copyright laws. If you want something less expensive, older versions are on line. For example, a legitimate 2009 map disk can be bought for $30-$40 if you can live with 5 year old maps (better than 2002 though).
The update is very easy to do though. The DVD head unit is in your trunk. Just remove the old disk and reboot with the new one. Just like any other DVD drive.
A lot of 2002 owners have also updated the nav system to a version 4, which is direct plug and play for our cars. Also a very easy update, with better graphics.
Lots of threads on all of these topics.
Old Oct 23, 2013 | 06:57 AM
416tt's Avatar
416tt
Someone also offered to update mine for 30$ in person.. say the disc will replace the one in my trunk.. I dont use my gps though because it always takes me the long way even with preferences set so i just use my phone..
Old Mar 3, 2014 | 02:53 PM
430red's Avatar
430red
Question? Looking to update my Gen 2/3 from 2.1 maps. Seeing newer Gen 2/3 maps on 2 discs, East & West. Will current system hold both discs or do you have to change them based on where you're traveling?
Thanks
Old Mar 3, 2014 | 03:42 PM
chrisv78's Avatar
chrisv78
The difference between east and west are local information like restaurants banks and motels. You get all of the roads with either version. You can buy both if you need them but they don't change significantly.
Old Mar 4, 2014 | 12:22 AM
430red's Avatar
430red
Thanks for the information! Makes sense.
Is the "override" limited to a certain version of maps for Gen 2/3 and how does one program the override?
Thanks
Old Mar 6, 2014 | 12:42 PM
430red's Avatar
430red
I purchased 13.1 maps for my Gen 2/3 today at local Lexus dealer & they installed it N/C.
Works great. Now, if I could only figure out how to be able to input info & changes while my wife is driving.
Thanks
Bob
2003 Sc430
Red/Ecru
JPBJR
May 16, 2012 05:08 PM
mdpuff
Aug 29, 2009 07:25 AM
SteadyEddy
May 15, 2009 06:25 AM
Youkai
Mar 28, 2008 08:28 AM
KWPTA
Jun 21, 2006 05:43 AM
