Door Removal and Speaker Replacement - PDF TUTORIAL
Old Oct 20, 2011 | 06:15 PM
edmondt's Avatar
edmondt
Correct I'm working on this right now... Got the driver side removed, now working on the passenger side...
They both blew, sounds like s buzzing bee.
Old Dec 10, 2011 | 03:49 PM
westxype's Avatar
westxype
Does anyone have a rear instruction removal pdf? I need to check my rear speakers.
Old Dec 10, 2011 | 10:47 PM
VVTiBob's Avatar
VVTiBob
see post # 92 in this thread https://www.clublexus.com/forums/sc-...he-test-7.html
Old Dec 11, 2011 | 10:38 PM
nwcn98's Avatar
nwcn98
Originally Posted by Harold57
The triangle weatherstripping replacement that eliminates the wind noise. The window adjustment portion needs to be added though.
I would be interested in this as well. I've replaced it once and I need to do it again, but this time have to lower the window a 1/16. I just don't know how to do it
Thanks for the great post
Old Mar 10, 2012 | 09:29 PM
Dallas6412's Avatar
Dallas6412
Default Thank you!!!!
I followed the instructions to the tee and even purchased the same speakers you installed. I could not have done it without your instructions. Nice work. Thanks again!!
UOTE=Daveychan;6693179]Hello,
This weekend i replaced my front-door woofers while using a very nice tutorial posted on this forum.
I'm posting that re-edited PDF for the door removal (i've made a few changes to that tutorial) and created a new PDF for the speaker replacement.
I hope that these will be helpful for someone else...
Thanks again to everyone who's given their time and effort to help others here! I couldn't have done it without you!
davey
P.S. - Apologies in advance to the mods for the re-post of material and ideas that have discussed many times here already, but i thought a new post with all the good ideas in one thread might be beneficial.[/QUOTE]
Old Mar 11, 2012 | 09:09 AM
bacardi's Avatar
bacardi
I have the DC Gold N69R in my car very nice speakers and great sound.
Old Jan 7, 2013 | 07:57 PM
kennylexsc's Avatar
kennylexsc
very nice intructions, thank you
Old Jan 12, 2013 | 02:17 PM
kennylexsc's Avatar
kennylexsc
so you can use High performance RTV silicon to seal the cracked front speakers? is this correct?
Old Jan 30, 2013 | 11:09 AM
Biddles's Avatar
Biddles
Awesome thread, needed this pretty bad. The guy I bought my SC from completely destroyed the doors getting the speakers in, I mean I need new panels destroyed. It's just awful. I love audio, but as much as I love audio I'm not going to destroy the interior trying to get it hooked up. Just crazy I'll do some before and after pics I suppose, I just keep forgetting to take pictures and just work on it instead.
Old Mar 9, 2015 | 09:20 AM
charmstr's Avatar
charmstr
Originally Posted by DrawDog
Thanks for this tutorial, it was very helpful when replacing my 6 X 9 door speakers. There were a couple of differences removing the door, I only had two pins and they were located on the black part of the door right near the front edge, up by the mid-range driver and tweeter. Everything else was the same except I also disconnected the lower door light connection... just made it a little easier to rotate the panel. I chose the speakers that were rated best in this shootout; http://www.soundstream.com/images/ma...ST6.9_shot.pdf They fit fine but although you have to trim two nibs on the plastic frame in order for the speaker to fit flush. I just clipped the nibs away with some wire cutters and then sanded them flat... everything else worked as shown. I did not connect up the tweeter that comes concentrically mounted in Soundstream's 6 X 9, I just orphaned it. My OEM speakers looked just like the ones in the tutorial, no edging left. :-o The bass from the Soundstreams is amazing! Even when cranked, they deliver tight, punchy, powerful bass. I had the grill covers flapping and still no distortion... sweet! I highly recommend them to anyone replacing their OEMs. I got mine from Amazon here http://www.amazon.com/Soundstream-SS.../dp/B0002W81YI It doesn't make it clear on Amazon's site, but the $77 bucks is for one box that has TWO speakers in it. Hope this helps!
In looking at the Soundstream Speakers on Amazon at the link you provided they indicate that they are 3 ohm speakers. Any problem with that since the OEMs are 8 ohms I believe? Thanks!
Old Mar 9, 2015 | 09:50 AM
bacardi11's Avatar
bacardi11
sometimes we learn from others mistakes.
Old Mar 9, 2015 | 01:31 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
There several stories of replacing speakers with aftermarket speakers. I personally found used Mark Levinson speakers on ebay and replaced everything that was bad. The system sounds really good and balanced.
Some People on here that seem to know stereos have said that using anything less than 8ohms may shorten the life of the ML amp.
Old Mar 9, 2015 | 06:31 PM
charmstr's Avatar
charmstr
Thanks! That's what I thought.
Old Mar 9, 2015 | 11:07 PM
texsexlex's Avatar
texsexlex
Originally Posted by Bgw70
There several stories of replacing speakers with aftermarket speakers. I personally found used Mark Levinson speakers on ebay and replace everything that was bad. The system sounds really good and balanced.
...lol...everyone on here that knows stereos didn't agree with that, but everyone here is happy with the decisions they made with their stereos & speakers
Old Mar 10, 2015 | 10:58 AM
ShawnOk's Avatar
ShawnOk
Hahaha, that is true texsexlex. But I am one that does agree with bgw70. After lots of experience, I feel why risk damage to the (ridiculously expensive and hard to find) ML amp, therefore I try to keep the same parameters assigned to OEM while improving with aftermarket products. I am quite happy with my upgrades as I'm sure everyone that has done the same in their own right is also content (as you pointed out). :-)
