Hood release cable
Old 08-25-10, 07:30 AM
roylee3
roylee3's Avatar
Angry Hood release cable
My hood release cable might be broken
the safety latch hold-but the main latch want catch.
It is connected inside the vehicle
how do i repair it-or-replaceit?
Old 08-25-10, 09:06 AM
VVTiBob
VVTiBob's Avatar
An actual failure of the mechanical cable itself sounds unlikely, however it may have become disconnected at one or both of two ends. You'll need to inspect it at both end to see if that is the problem. If so, then reseating the cable should fix it.
The cable itself snakes from under the dash, just right of the trunklid release switch, through the firewall and up to latching mechanism. At each end the cable should have a lead slug which fits into corresponding receiver and mechanical lever. I have a diagram around here somewhere if you need one.
Old 08-25-10, 11:53 AM
roylee3
roylee3's Avatar
I had a Mechanic friend look at it and the latch seem to be sticking--He was able to move a small screw drive around by the latch and the release would connect. However, I have to do that each time I open the Hood and close it. MAY NEED NEW LATCH AND CABLE. WHER CAN I FIND THEM? THANKSthanks for the diagram and info
Old 08-25-10, 02:55 PM
SC430Sam
SC430Sam's Avatar
Mine is broken right now. I am taking my car in tomorrow for a service, and since I am still under warranty I am going to have them replace it. I think the plastic clips on it (that hold the cable) broke.
Old 02-05-11, 03:57 PM
svlexus
svlexus's Avatar
If it wont open its the cable, if it wont close its the latch.
Old 07-27-13, 07:38 AM
mawbell3
mawbell3's Avatar
My bumper was hit. It popped one time but could not get latch to release. Any suggestions?
caddylover
11-15-18 07:15 PM
edbro
RX - 1st Gen (1999-2003)
01-10-18 08:23 AM
Mike246
01-02-18 09:58 AM
roylee3
09-17-10 12:32 PM
AppleJuice
05-29-10 07:23 AM
Quick Reply: Hood release cable
