Help - - Trunk Rams / Struts
Old Jul 22, 2010 | 02:54 PM
Enguin's Avatar
Enguin
Default Help - - Trunk Rams / Struts
I have a 2002 SC and the gas rams for the trunk lid have softened and do not hold the lid up anymore....... I spoke with Lexus and was amazed at the cost of two replacement rams and before I shell out $600 does anyone know if there is alternative vendor for these items?
Thanks for you help and advice.
Old Jul 22, 2010 | 03:12 PM
tfeni52355's Avatar
tfeni52355
Default Please use the search feature
EBay - About $60. Search, Search, Search the posts. There is virtually no topic about this car that has not been posted multiple times.
Old Jul 22, 2010 | 06:00 PM
aquanuke's Avatar
aquanuke
Have to say the eBay ones are better then the oem ones had mine for years Now no problem
Old Jul 22, 2010 | 06:11 PM
JerryB's Avatar
JerryB
As I have mentioned before, another option is:
www.napaonline.com
Lots of options out there,
Jerry Baumchen
Old Jul 23, 2010 | 04:03 AM
EJC's Avatar
EJC
www.napaonline.com
Jerry Baumchen
the trunk struts lasts 3-4 years then die.
This happend on my '02 and then on my '03. Both cars were CPO so it was covered under warranty, but I think I asked at the time and the price was no where near $600 (could be wrong on this).
On the other hand, it should be simple to pick up the parts and pop them in yourself or have your mechanic do it.
Old Jul 23, 2010 | 08:42 AM
VVTiBob's Avatar
VVTiBob
If I remember correctly, OEM struts, called "lift support cylinders" for SC430 are about $112 each. If the dealer wants to charge you $350 labor I'd run as fast as I could from them. It's a 10 minute job for experienced mechanic and maybe 20 minutes for you if you take your time AND drink a cup of coffee.
Follow the link and read the thread about the same problem. I posted a diagram in the thread with instructions on how to replace them yourself. https://www.clublexus.com/forums/sc-...the-trunk.html
Last edited by VVTiBob; Jul 23, 2010 at 08:53 AM. Reason: added info and link to another thread
Old Jul 26, 2010 | 11:54 AM
Enguin's Avatar
Enguin
Default Thanks
Thanks to all who replied, you've been a great help and soon I'll be able to use two hands to load the trunk.
Old Jul 28, 2010 | 07:37 AM
pageme1911's Avatar
pageme1911
Hey, I replaced them myself and they work just fine. I got them off of Ebay for $44.00 a pair. Good luck!
Old Jul 28, 2010 | 08:20 AM
Irishvol's Avatar
Irishvol
Default You can get struts at any auto parts shop
For about 1/2 what dealer charges. If you have any skills at all you can install yourself in 30 minutes.
Old Aug 3, 2010 | 02:25 PM
RGP's Avatar
RGP
I just installed a set of supports from NAPA for $120 each. They seem to work fine and took less than 5 minutes to install. Two things to watch out for though. Make sure you get the right part number for a trunk with or without a spoiler - there is a slight length/force difference. Also make sure you get a matching set of supports when you pick them up. They have three different types of end fixtures (all ball joints) some are metal and some are plastic. The first time I picked up a set they had two different styles of joints on them (one set had plated joints and the other had plastic ones). I had them order another set which had a third type of joint on them that was exactly the same as the stock units (black metal).
KWPTA
Dec 30, 2008 10:11 PM
ratha67
Nov 10, 2008 12:16 AM
mrblister
Jun 11, 2008 05:07 PM
Jwhite
Oct 23, 2007 09:49 PM
PERRYinLA
Mar 11, 2004 12:13 PM
