Shaky Steering - New Ball Joints
Tie rods, ball joints, and control arms can all contribute to vibration. None of my cars have any type of vibration (30-110 degrees, does not matter). My SC had a little not too long ago which was alleviated with a new control arm.
Early GS400's had severe issues which required new suspension components. Road Force balancing will really assist trouble childs.
When they did my alignment they missed the worn control arm, or at least did not mention anything to me. This ended up costing me another alignment after I replaced it with a new unit.
They should do an inspection, should.
A thorough inspection only takes 10 minutes with a good sized pry bar.
That's what I suspected. Now I have to find a suspension specialist to troubleshoot.
Ain't going back to the dealer after that fiasco. Any member know a good suspension place in the Seattle area? Thnx.
I just went thru this with my sc, bought good years GS-D3 from tire rack, had shake in steering wheel at 55-60 right away, had tires rebalanced, helped but still shook slightly at 60. Went to different tire shop for road force balancing, found frt tires too out of round to balance. Called tire rack and exchanged tires for Bridgestone re960's, had tires road forced balanced no more shake and totally smooth ride. 40k warranty on the Bridgestones- will see!
I had an -02Sc that never had a balance problem. I had removed the Runflats and put on some Dunlops.
Last year I switched to an '03SC. Again switched to Dunlop Direeza 101s. Car ran great. At 5K miles I had the tires rotated & balanced with the service.
As soon as I pulled out of dealership and hit the highway I noticed a vibration at highway speed. Called the dealer from the road and discussed it. Took the car back a couple of days later, they put the wheels back where they had been, car was smooth again. We are going on the assumption that suspension wear to the tires caused the difference between front and rear.
So I will not bother rotating.
If the tires wear out before the lease is up I'll put the run-flats back on to finish the lease, 1.5yrs to go. We only did 7K miles in a yr and a half, so I think I'll make it.
colombianc
Suspension and Brakes
22
Mar 7, 2011 01:26 PM
