Fog lights with parking lights
How difficult is it to set up the fog lights to be on with the parking lights? Is this a wiring issue or can it be programmed?
Thanks JTMav |
if it's anything similar to the 2gs, then it's not that easy, you have to do some wiring. where is lee?
and nop, you can't do it through programming |
it should be a wire that goes into a relay that turns the fog lights on when you hit the switch. You cut that wire and tap it into the DRL wire and you done. If Lee has the wire diagram it should be easy to figure out.
As Tony mentioned, easy to do. Just tap the relay postiive wire for the fogs to the DRL wire. If you need a wiring diagram of the SC shoot me a PM with your email address. But keep in mind that the fogs will only burn out that much quicker and they are a (*&(*&(* to change on the SC.
Lee |
yeah maybe lee can show the diagram, coz' somehow it's not as direct as that on the IS300.
Lexus Personalized Settings (LPS)
Just in case anyone is intertested!
"Personalized Settings Options ' for SC PDF. |
