FL Full Plug n Play MK4/SC V160 6spd Drivetrain
Old 04-10-18, 01:55 PM
S14eva1
S14eva1's Avatar
Default Full Plug n Play MK4/SC V160 6spd Drivetrain
This is a complete setup from flywheel to rear end. Direct bolt on for SC/Supra platform. About 70k miles, originally came off a 93-96 JDM MK4 Supra. Shifts very smooth, zero grinds Only used Royal Puple syncromesh. Car made 841whp on this setup. Never launched as it was built for highway rolls.Can include Master cylinder/Pedal assembly if necessary.
Includes
Complete V160 trans
B&M billet short shifter
New Dual mass flywheel
New throughout bearing
New slave cylinder + clutch fork
SouthBend stage 3 drag clutch (2.5k miles...broken in 1k miles as per instructions)
Stock 2 piece driveshaft
SuperFlo front diff bushings (Not pictured)
3.1 220mm Diff with stock torsen lsd (OS Giken 1.5way not forsale)
220mm MK4 axles
Asking 10k firm.
S14eva1 is offline
Old 04-13-18, 05:30 AM
mteele
mteele's Avatar
Given the current market, I think this is a great deal for someone!
mteele is offline
Old 04-14-18, 05:22 AM
gerrb
Super Moderator
gerrb's Avatar
OP - as per forum rules ... no testing of waters . It is either for sale or not
You would need to clarify ... if every part will ALL be bolt in to an SC or a Supra MKIV . IT IS NOT POSSIBLE FOR BOTH CARS on ALL PARTS stated above.... for the simple reason that the SC has a longer wheelbase . The driveshaft will only work for the SC or Supra MKIV depending on what car this setup last came out from. The SC will need a longer driveshaft than the MKIV.
gerrb is offline
Old 04-16-18, 05:18 PM
phamxOC
phamxOC's Avatar
trade you a 6 speed g35 salvage and cash on top for it
phamxOC is offline
Old 04-19-18, 07:55 PM
S14eva1
S14eva1's Avatar
Thanks but, No trades.....Last call before setup goes back in the next few weeks.
S14eva1 is offline
TheGerman
11-01-12 12:28 PM
Strokergsr
Performance & Maintenance
06-05-09 02:13 PM
Kruso
03-18-08 11:46 AM
ScottURnot
01-12-08 11:52 AM
2jzsc313
02-08-03 11:06 AM
Quick Reply: FL Full Plug n Play MK4/SC V160 6spd Drivetrain
