PA MVP Motorsports Boost Cut Control Device.....$$$
Old 05-15-15, 12:17 PM
CatManD3W
CatManD3W's Avatar
Default MVP Motorsports Boost Cut Control Device.....$$$
Up for sale is my BCC that I purchased from MVP (Same thing as Greddy BCC)....this is used to eliminate the factory boost cut from your 2jzgte ECU...it allows you to run more boost.....I decided not to use this as I am saving up to buy a map ecu...
This is very simple to install.....simply cut map sensor wire.....pin 62 on 2JZGTE ECU pinout......Green wire goes to ECU side and White goes to sensor side
The red wire is for a 12 volt source....I just tapped into cigarette lighter for this and black is for a ground....
Only takes about 10 -15 min to install
It is tuned at 4.1 volts
These go for $120 new from MVP....
I can let this go for $75 obo shipped.....PM me if interested
CatManD3W is offline
Old 05-18-15, 03:54 PM
CatManD3W
CatManD3W's Avatar
Bump....Price lowered to $65 shipped....
Old 05-23-15, 09:24 AM
CatManD3W
CatManD3W's Avatar
Bump...Still available
Old 05-25-15, 11:35 AM
mikef
mikef's Avatar
Im about to bpu my twins for now and this is what i need for my map ecu right?
mikef is offline
Old 05-25-15, 02:30 PM
CatManD3W
CatManD3W's Avatar
All this does is eliminate the factory boost cut on ECU....it allows you to run more than the factory 14psi that is limited by the ECU...
You can run as much boost as you want as long as you have enough fuel
Old 05-26-15, 07:56 AM
CatManD3W
CatManD3W's Avatar
Sold!!!!!!
scmaluco
Performance & Maintenance
12-14-15 07:15 AM
bryan767
05-03-14 04:37 PM
WICKED 1
01-29-08 11:46 AM
atekt
04-12-06 08:51 PM
Kylestt
SC400 / 300 Classifieds
11-15-05 10:41 AM
Quick Reply: PA MVP Motorsports Boost Cut Control Device.....$$$
