Climate control discolored? Simple fix
Old Jul 15, 2006 | 06:34 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Default Climate control discolored? Simple fix
As this appears to be a common occurrence on these cars, I picked up a spare unit to play with.
The good thing is that it appears to be a simple fix. I used my trusty Meguiars Plastx and after some polishing the discoloration was completely gone. See the pics. I also cleaned the unit on my car and it is as new.
Just an FYI for those that run into this.
Lee
BEFORE
AFTER
TAKEN APART
PRODUCT USED
Old Jul 16, 2006 | 07:33 PM
talwang's Avatar
talwang
so it was not the anti-reflective coating you just removed, correct?
Old Jul 16, 2006 | 07:53 PM
redmr2's Avatar
redmr2
Question
Thanks Pearlpower , for that info . . . someone earlier had suggested the use of alcohol but that makes me a bit nervous. I looked for the Meguairs product you mentioned at my local autoparts store, but it wasn't available, seems like it's the type of thing I may have to order online. I'll place my order in the a.m. . . . Will I need to remove my faceplate, though, to get mine to look as clean as yours (arrgghh!) or can I just apply the Plastx to the outside ?? . . . Thanks again . . .
Old Jul 16, 2006 | 08:01 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Hmmmm, you know, I am not sure if that is the anti reflective coating or not that gets discolored, if it does have one. What I do know is that there was no issue with the display today with the top up and down in 107 degree heat. Crystal clear and I was pretty happy I did it as it looks as it should with no issues. No need to remove the unit from the car. Just clean in display installed in the car.
I purchased this one from Kragen Auto.
Lee
Old Jul 17, 2006 | 09:50 AM
rominl's Avatar
rominl
exclusive matchup
damn another nice post from lee, good info there man!
Old Jul 17, 2006 | 04:17 PM
sexylexysc430's Avatar
sexylexysc430
same thing happened to mine...i believe i read something on here about using Lysol antibacterial wipes, and decided to give it a try since i always use them. it worked! It takes some gentle rubbing but the wipes are soft and didn't leave scratches as far as i could tell
Old Jul 20, 2006 | 07:17 PM
golfkwesi's Avatar
golfkwesi
I had a similiar problem but mine was not as bad. It rather looked "cloudy" on the inside. My '02 warranty expired on July 1st - the dealer replaced it under warranty.
Thanx for the tip - though I hope I won't need it.
Old Jul 20, 2006 | 09:43 PM
rominl's Avatar
rominl
exclusive matchup
just make sure you use nothing but water damped cloth to clean it now
Old Jul 26, 2006 | 10:23 PM
mike12079's Avatar
mike12079
I will give this one a whirl. Looks like a great Idea though.. THANK YOU
Old Feb 23, 2008 | 08:01 PM
gls24's Avatar
gls24
I am unsure as to how to take off the plate. Can anyone supply step by step removal instructions? I too am having this problem and it looks bad. Thanks
Old Jul 18, 2011 | 01:22 PM
LuxeFilms's Avatar
LuxeFilms
Pearlpower, can you please repost your pics. Just like gls24, I am having the same problem and looking for a solution. Mine appears that the gunk is behind the glass/plastic. Is there a way to remove the glass/plastic to clean the back side? Thanks!
Old Jul 20, 2011 | 10:07 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Photos reposted due to requests.
Old Jul 21, 2011 | 04:20 AM
SteadyEddy's Avatar
SteadyEddy
From: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
To Whomever, would this also work on our nav screen? On btw thanks for the info on the other screen, I'll have to see if I can get Meguire's plastx.
Old Jul 25, 2011 | 08:48 AM
LuxeFilms's Avatar
LuxeFilms
Thanks Pearlpower! How do you pop off the faceplate on a installed unit?
Old Jul 25, 2011 | 09:46 AM
mandyfig's Avatar
mandyfig
Has somebody tried this on the NAV Screen?
