Need antenna help
Old May 12, 2009 | 04:58 PM
pmpdaddyt's Avatar
pmpdaddyt
Exclamation Need antenna help
I need help quickly....
How do i remove the antenna?
i was looking at this pic and maybe i'm retarded but i dont get it.
https://www.clublexus.com/forums/sc-...reception.html
which of these can i use to hook my antenna to a power source?
Old May 12, 2009 | 05:14 PM
kevincao01's Avatar
kevincao01
On the exterior of the car, there is a ring around the antenna (gold/silver depending on our car emblem color). You have to unscrew the ring first. See if you can get anywhere by doing that first. Hope this helps.
Old May 12, 2009 | 05:19 PM
pmpdaddyt's Avatar
pmpdaddyt
will do
thanks kevincao01
Old May 12, 2009 | 06:05 PM
pmpdaddyt's Avatar
pmpdaddyt
Got It!!!! yeah!!!! but i think i need a 12v source, some of my stations aren't picking up, any suggestions guys and gals???
Old May 12, 2009 | 06:20 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
By an aftermarket one that only needs a remote turn on, 12 volt, and ground. Throw the OEM one in the garbage. My opinion. They sell for around 20 on Ebay. Alot of the plastic gear and antenna part break on the inside of the motor. Plus, the OEM one only raises at fully extended when its required, or if the signal requires it to, if I am not mistaken. It doesnt raise fully all the time. If you use an aftermarket head unit, it requires the use of only 2 wires to work, by tapping into them. Heres the link to Lextreme on the wiring of the antenna and the full audio system 92-96 though.
http://www.lextreme.com/Lexradiowcd.pdf
Old May 12, 2009 | 06:35 PM
ThomasGS4's Avatar
ThomasGS4
I got one of those fleabay antennas installed. I bought it for 18.99 I think? Anyway, can't help you on the install because one of my buds installed it for free at his shop
Old May 12, 2009 | 07:28 PM
Luxor's Avatar
Luxor
When you take off the antenna, can you take a picture of the hole and give me the dimensions of the hole? I need this info so I can find the right plug when I remove my antenna.
Old May 13, 2009 | 01:32 PM
King7Two's Avatar
King7Two
CL Folding 200,000
I just yanked mine out and installed the flex from locustom (ebay)
I just had to locate the 12v radio source in the harness with an amp meter
Total installation took about 10 min's.
Works great.!!
Old May 13, 2009 | 06:42 PM
xzeus's Avatar
xzeus
do you happen to remember which wire was the 12v source?
Old May 13, 2009 | 07:20 PM
King7Two's Avatar
King7Two
CL Folding 200,000
No....unfortunately I don't.
But I can look tomorrow. (someone else asked about a plug dimension)
Anyone could chime in though.!!!
I'll look in the morning and report back.
Old May 13, 2009 | 07:41 PM
King7Two's Avatar
King7Two
CL Folding 200,000
Hole is 25x35 oval
Old May 13, 2009 | 07:44 PM
King7Two's Avatar
King7Two
CL Folding 200,000
12v source in the harness is the green w/yellow stripe
Dont cut the harness. Just plug one wire into it.
Old May 21, 2009 | 04:30 PM
pmpdaddyt's Avatar
pmpdaddyt
1. Cut the red wire end
2. twist the wire end, and locate the gray wire on the harness (I have a 92 sc400, i think they are different from king7two)
3. insert wire into the slot for the gray wire
4. Enjoy the static-free tunes
Old May 21, 2009 | 06:08 PM
Luxor's Avatar
Luxor
Originally Posted by King7Two
Hole is 25x35 oval
25mm x 35mm Thanks!
Old Jun 13, 2009 | 04:05 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
lol when im looking for power sources, i usually just stick it in every hole until it starts working, then flip the key from on to off just to make sure its not always live.
