My car has had a battery drain issue for a while now. I just noticed that when the car is turned off and the key is removed, the parking lights remain on. I've checked the light switches and they are all turned off. Does anyone know where I should start looking for the possible issue? Maybe if I fix this, my battery drain will go away...
I've checked the drivers fender liner and there is no harness there on my car. I'm thinking that there might be an issue under the radio in the center console. Perhaps there is a wire there that is grounding out...
how did you wire your dimmer I am about to do it for my gauges?
I have not rewired it yet, but I will tap into the dimmer wire on the head unit. If you have an aftermarket radio, you can tap into the dimmer wire there.
