SC- 1st Gen (1992-2000)
Oh please, Gucci SC, owner fibbing on mods...
Old 06-13-03, 03:05 AM
  #31
sweetsc400
sweetsc400's Avatar
Yeah I just saw the page. I feel as though I need to wash my hands now. . .I've lost my appetite as well. . .
sweetsc400 is offline
Old 06-13-03, 05:01 AM
  #32
Keith13b
Keith13b's Avatar
Originally posted by SC400-V8
Speakin of engine cosmetic wear, mine is showing some light oxidation here and there on the top of the block, (right valve cover with the "4-cam ...." script still looks fantastic), but the top of the block near the lexus emblems starting to show it. How can you remove that stuff?
In the interest of a mint-looking engine compartment.
A light wet sand w/ 400 grit or buff it w/ steel wool. Then apply a good metal polish.
Keith13b is offline
Old 06-13-03, 09:51 AM
  #33
strongsail
strongsail's Avatar
um, I'd say don't use steel wool - it will leave litle bits of steel on the surface which will turn to little rust spots - if the corrosion is light, wet-dry sandpaper and light oil may be all you need. You can get good aluminum polish at marine stores like West Marine.
<edit> oh yeah, regarding the subject of this thread, I have one word for that gorked-up SC on ebay:
GAAAAACK!
strongsail is offline
Old 06-13-03, 12:05 PM
  #34
SC400-V8
SC400-V8's Avatar
Its not that i'm dumb, but Ive heard of this wet sandpaper, wet sanding alot, and still have no idea of what it is exactly.
SC400-V8 is offline
Old 06-13-03, 12:29 PM
  #35
Keith13b
Keith13b's Avatar
Its an emery sand paper (looks black) that you needs to get wet before sanding, then keep wet as you are sanding. If not, it makes a lot of dust and clogs itself instantly. Look for it in the bondo section of the auto parts store. Its looks and acts just like regular sand paper, cept for being black and needing water.
It makes a very nice and smooth polish on hard surfaces (body panels, bondo, metals, etc.)
You can also use it to polish plastics, and remove scratches in paint (assuming to have a buffer to polish up). It comes in all different coarses up to 2000 grit (at least that I know of). Its a body shop essential.
Keith13b is offline
Old 06-13-03, 12:35 PM
  #36
Keith13b
Keith13b's Avatar
Only the cheap stuff. They have stainless thats a hell of alot more durable but does cost more. Don't use the steel wool from under the sink or for refinishing wood, as that stuff does break apart and will stain. Get a high quality stainless or brass (copper works too, but its soft and can smear copper leaving the color behind). They can be found in industrial supply stores and chemical supply catalogs.
Good luck.
Keith13b is offline
Old 06-15-03, 01:26 PM
  #37
EmeraldLexuSC3
EmeraldLexuSC3's Avatar
Post Lowered price to $17K
I guess $20k was too much for the asking price, so he lowered to an afforadable price of $17K
EmeraldLexuSC3 is offline
Old 06-15-03, 01:48 PM
  #38
sweetsc400
sweetsc400's Avatar
has anybody else written any comments to this guy?
Old 06-15-03, 01:57 PM
  #39
O. L. T.
Keeper of the light
O. L. T.'s Avatar
29 mins to go.... wonder why the reserve hasn't been met?
O. L. T. is offline
Old 06-15-03, 08:08 PM
  #40
SC400-V8
SC400-V8's Avatar
Ok, i got a set of wet or dry sandpaper (3M) various grit ratings from 220- all the way to 1500. Tommorow im just gonna try it out and try to get my block to look cleaner. Ive decided not to use a polish or anything, just wetsanding and wipe to get clean is all.
SC400-V8 is offline
Old 06-16-03, 05:46 AM
  #41
Keith13b
Keith13b's Avatar
Good luck, its not hard, but always keeep too much water on it when your sanding. I would get the hose out and have it run a little bit of water non stop while you are sanding. Get a wood block or a rubber block so you are pressing with a flat surface. Don't just use the paper in your hand. Always sand in the same direction and go lengthwise for best results. When sanding metal, the paper wears out quickly, so change often.
I hope I don't sound like I'm telling you what to do, I'm just passing on lessions I've learned in the past.
Keith
Keith13b is offline
Old 06-16-03, 07:18 AM
  #42
eric150db
eric150db's Avatar
oh snap yo that cat must have caught some serious coochie rockin tha gucci! hhahahahhahah
eric150db is offline
Old 06-16-03, 07:32 AM
  #43
SC400-V8
SC400-V8's Avatar
Default done
Ok... it was a much more tedious process than i originally anticipated, but it does look much better.
SC400-V8 is offline
Old 06-16-03, 07:34 AM
  #44
SC400-V8
SC400-V8's Avatar
... and the only area I really did was the top of the block right behind the lexus script and "L", all those ribs. I must say the two wires from the traction control box made the job very difficult.
SC400-V8 is offline
Old 02-07-05, 07:09 AM
  #45
Taka
Taka's Avatar
Speaking of Gucci mod..
Found Gucci SC shift *** on yahoo aution japan.
pic1
pic2
pic3
it says on the description, Buy It NOW price $200!!!
Taka is offline
Stage3
02-20-09 06:29 AM
GSoup
NELOC
11-23-07 08:56 PM
SilverLexo
43
06-26-06 08:44 AM
Quick Reply: Oh please, Gucci SC, owner fibbing on mods...
