CA Catalytic Converter 97 vs 98-99 - ClubLexus - Lexus Forum Discussion
SC- 1st Gen (1992-2000)
Thread Tools Search this Thread
Old 05-24-17, 10:36 AM   #1
SuPrAmAn69
Default CA Catalytic Converter 97 vs 98-99
Sup guys, I have a 97 RSP and I need a new cat. I looked up the part numbers and came up with
17410-46330, list price is around $1k. I also seen the converter for 98-99 which is 17410-46470. List price is $350!! Anybody know if the 98-99 fit the 97 and pass smog? Why such a price difference?
SuPrAmAn69 is offline   Reply With Quote
Old 05-24-17, 11:23 AM   #2
mjeds
Toyota Part No.: 17410-46330 PIPE ASSY, EXHAUST, FRONT
Part Fitment
Toyota Supra 1995-1998 6 Cyl 3.0L 2JZGE; JZA80
Pipe Assembly Exhaust - Toyota (17410-46470)
Part Fitment
SC300 1997-2000 6 Cyl 3.0L 2JZGE; JZZ31
SC400 1997-2000 6 Cyl 3.0L 2JZGE; JZZ31
Looks to me like the first one is not for your car, the second one is.
mjeds is offline   Reply With Quote
Old 05-24-17, 11:47 AM   #3
SuPrAmAn69
I've type my VIN in several lexus parts sites and was given the first number as the one for my car.
Old 05-24-17, 11:48 AM   #4
mjeds
odd, the second on is clearly for your vehicle based on this:
https://www.lexuspartsnow.com/parts/...410-46470.html
cheaper from their Toyota site:
https://www.toyotapartsdeal.com/oem/...410-46470.html
Old 05-24-17, 11:53 AM   #5
SuPrAmAn69
Yeah no idea. I will gladly pay $315!! Just checked lexuspartsnow with my VIN and it says it does not fit.
Old 05-24-17, 11:59 AM   #6
mjeds
wait, do you have an SC or a Supra?
you posted in the SC forums so I presumed you have an SC.
not likely to fit, even though they have the same motor, it isn't just the motor at issue, but the mounting points and fitment under the car.
might check with your local muffler shop and see if an after market will work.. I have a 1995 4runner than had a blown cat, and I passed smog legally with a flowmaster after market cat, that cost me $180 installed.
Old 05-24-17, 12:11 PM   #7
SuPrAmAn69
I have an 97 SC300, thats what i was wondering, if anybody knows if the fitment is the same or not since its the same motor. Thats a huge price difference if the mounting points are just different.
Old 05-24-17, 01:40 PM   #8
KahnBB6
SuPrAmAn69,
For aftermarket cats that will work on a Cali-Spec SC300, use this resource to verify what you are buying:
https://ssl.arb.ca.gov/PartsSearchTo...earchTool.aspx
The equivalent Supra cat will probably work since it's the same engine and emission system (assuming CA-Spec for CA-Spec... and Federal for Federal) but note that the Supra has a shorter wheelbase and thus the OEM 2nd catalytic convertor pipe/assembly is shorter and would require an extension adaptor. I haven't tried running this by an inspector yet myself with my SC but the last time I had my smog test the technician did go under the car to verify that either an OEM cat was present or that an aftermarket cat was present that is legal for my model year. He did verify the E.O. number on the cat with a mirror. I am not sure if anything used to extend the pipe would throw him off.
Functionally a 1998 Supra NA 2nd OEM cat pipe is designed to work the same way as the pipe/cat in a 1998 SC300. Supras were discontinued after 1998 however and still, California BAR would say you can't use the Supra cat/pipe... even though it does the same thing as the SC version for 1998 models. 1999-2000 wouldn't apply... legally.
This thread might help to give you an idea about where things stand with aftermarket cats for SC's although most of the notes apply to earlier pre-OBD2 models:
https://www.clublexus.com/forums/sc-...a-legal-3.html
KahnBB6 is offline   Reply With Quote
The Following User Says Thank You to KahnBB6 For This Useful Post:
Ezroni (05-25-17)
Old 05-25-17, 01:37 AM   #9
SuPrAmAn69
Quote:
Originally Posted by KahnBB6 View Post
SuPrAmAn69,
thanks for the reply, and yes I've read that thread numerous times with no luck in my situation. I don't want to go aftermarket since there's no real direct placement available. I really just want to know if these two parts are interchangeable, if anybody has any experience on it, as I'd rather spend $350 than $1200.
Old 05-25-17, 07:51 AM   #10
KahnBB6
I have no direct experience with this scenario but the engine design and ECU design in terms of emissions control should be identical for a 1998 MKIV Supra NA Auto (they only came in automatic for '98 just like the SC300) and a 1998 Lexus SC300. The 2nd catalytic convertor should be the same thing for both cars, just in a pipe that is slightly shorter than the version for the SC300. Has anyone tried this and proven it with visual confirmation? I am not sure... but since the 2JZ-GE and support systems for them in both cars are nearly identical it would make sense to me.
Now... will your smog inspector take any issue with extending that pipe with a small adapter or a welded extension, even though this otherwise looks like (and is) an OEM cat convertor pipe? Not sure on that either.
Will it work exactly like the OEM 1998-2000 SC300 cat convertor assembly? Again, I can't say from experience but I would assume it does, especially if you're buying a 1998 part for a 1998 part designed for the same exact engine configuration, transmission configuration and the same ECU programming between both cars.
Edit: I just re-read your first post and remembered that you have a 1997 SC300. In that case, the engine configuration is slightly different between both '97 SC300's, '97 Supra NA's and '98+ SC300's and '98 Supra NA's. Identical for the same model years of each vehicle but not the same between '97 and '98 since that was the switch to VVT-i.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2017 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
