SC- 1st Gen (1992-2000)
Supra sway bar mounts discontinued
Old 02-03-17, 01:57 PM
SC510
SC510's Avatar
Default Supra sway bar mounts discontinued
Just giving everyone a heads up, I tried ordering subframe mounts for the supra sway bar conversion from toyota of dallas and i was told that # 52205-14020 was discontinued. The other subframe mount is on backorder. Gonna have to order the solid frame mounts to complete the conversion for me
Old 02-03-17, 04:39 PM
KahnBB6
KahnBB6's Avatar
Received 1,216 Likes on 854 Posts
It was bound to happen eventually. There are Battle Version's solid MKIV subframe mounts as you mentioned. I am not sure of other aftermarket options currently available. I did not see anything like this on the Figs Engineering website even though they make many suspension components for SC's.
Old 02-03-17, 10:49 PM
SC510
SC510's Avatar
Powerhouse racing makes a similar set. And i just ordered a TMS set from suprastore for the same price as the OEM ones.
Old 02-04-17, 08:20 AM
Boergy
Boergy's Avatar
i welded seperate holders on my original SC mounts and installed PU inlets works fine
greets
Tom
Old 02-04-17, 11:58 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
I was hoping they wouldn't discontinue these yet. I'm still in the process of replacing my suspension parts.
Old 02-04-17, 02:23 PM
Blkexcoupe
Blkexcoupe's Avatar
greets
Tom
Did you think find the super pro inserts to be an added improvement? I've been debating about installing a set on my car.
Old 02-04-17, 08:20 PM
KahnBB6
KahnBB6's Avatar
greets
Tom
^^ The SC/Soarer Z30 mounts are really no different than the MKIV mounts other than the rubber formulation (maybe) and those extra mounting plates. I can also see conversion services for SC rear subframe mounts being offered if any company that services the SC's wanted to get into that. MKIV version swaybar bushing mounting plate positions would need to be copied for this, however.
I compared them side by side a few years ago when I got my MKIV versions and I laughed at how they were almost the same thing... except for the extremely crucial extra mounting mounts for the Supra MKIV swaybar.
Old 02-07-17, 01:27 AM
Boergy
Boergy's Avatar
hi! yes! i installed also the front inserts for the subframe and the for the front diff mounts. the rear feels much less spongy, more response, more exact, but a little bit more noise from the wheels and suspension.
Old 02-07-17, 07:44 PM
Blkexcoupe
Blkexcoupe's Avatar
Thanks for replying. That sounds like a great improvement for the rear end, but I'm currently trying to find what is creating noise in my rear end end right now. I'll hold off on installing a set until I can isolate the noise first.
Kilo
Suspension and Brakes
27
04-08-11 05:26 PM
Papajorgio
06-12-09 12:44 PM
kietlander
03-29-06 01:35 AM
TRDSupraSE
09-09-05 05:16 AM
Quick Reply: Supra sway bar mounts discontinued
