Missing at medium RPM's
If this happened to my trusty MGB, I'd say it was plug wires.
Any thoughts anyone? Has anyone changed plug wires on a SC4? How difficult is it?
Thanks
Plug wires are a good place to start. Sounds like you've taken your car to the dealer ??? "120,000 mile service" The dealer NEVER changes the plug wires for a service so you might be due. I reccomend changing the wires every 60k or even 30k miles along with your plugs. They are not hard to change if you buy the OEM dealer stuff which comes with all the tabs and seperators. No experience with aftermarket. Although I'd love to put some 8mm or 8.8mm wires in ... somehow.
Regards
Purchased and had them shipped from a dealer in Califorma for less than $100
I seem to notice it mostly when the engine is nearly warmed up (been driven for two minutes, but not up to normal temp). I notice it mostly go to and from work on surface streets before I hit the freeway.
It seems like I can lessen the problem by pressing down on the gas pedal or releasing the overdrive. It is almost like driving a manual transmission vehicle in four-gear and trying to accelerate up from 20mph (that's why releasing overdrive seems to help).
I looked at the left side of the engine's plugs and wires a month ago, but they looked excellent.
All wires met the resistance specs with resistance < 15 ohms, but in some had deep cracks in the insulation.
Handling and response is much better. The mid-rpm misses are gone.
By the way, I'd never have bneen able to do the ignition wire exchange if I hadn't had the DIY instructions from the list. Thanks a bunch everybody!
