quick mass airflow sensor question....
Old May 5, 2003 | 05:42 PM
hamid's Avatar
hamid
Default quick mass airflow sensor question....
i have a 95 5 speed sc, and i was thinking about the mass airflow sensor mod on our cars, gettin the ones from the sc400/ls400. i was curious if the mass airflow sensor for a 1995-1997 ls400 or one for a 1997 sc400 would work. i am pretty sure they will fit, but i want to be positive. also will i need safc for tuning or will it be fine without one?
thanks
Hamid
Old May 5, 2003 | 06:16 PM
NRG's Avatar
NRG
i dont think it will give you any performance by swaping it to the sc300 MAFS
Old May 5, 2003 | 09:30 PM
hamid's Avatar
hamid
i am relatively sure it does because there was a thread on it before and the person said it made quite a difference....
does anybody know if i should be getting a specific year MAF?
thanks
Hamid
Old May 6, 2003 | 07:55 AM
ChrisK's Avatar
ChrisK
hamid,
95-97 LS400 or 96-97 SC400 use Mass Air Flow sensor while your 95 SC is using Karman Vortex Air Flow Meter. They are two different sensors/meters.
94-91 LS400 and 92-95 SC used Karman Vortex Air Flow Meter, where SC400's is bigger in size than SC300's.
Old May 6, 2003 | 09:56 AM
henrynguyen's Avatar
henrynguyen
Thumbs up V-8 AFM and SC300 AFM
The only different between V-8 AFM it have a bigger bypass(the air will not be measure by the sensor) and it is allow you to adjust the amount of air bypass the AFM. Result would increase HP. If you don't do it right, result will be high RPM idel.
Old May 6, 2003 | 05:42 PM
hamid's Avatar
hamid
thanks for the answers guys! it would have stunk hardcore if i bought the wrong one and tried to put it on...
thanks
Hamid
Old May 7, 2003 | 07:04 PM
Bean's Avatar
Bean
CL Folding 1,000,000
putting the maf on without tuning will also make you run super duper lean
philliptie
SC400 / 300 Classifieds
Apr 24, 2010 04:09 AM
sc4001992
Dec 2, 2008 11:16 PM
Kilo
Nov 11, 2008 08:28 AM
alaiwat
Oct 22, 2007 07:54 AM
