ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   can't peel out, have a question (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/81900-cant-peel-out-have-a-question.html)
ztikmedia Apr 26, 2003 03:52 PM
Last night I took my car out the highway to see what it could do.
Right away I floored it and it wouldn't even peel out!
I had my ect in power mode and my traction control off. I also have a dragon torque converter installed so I was almost sure it would peel out easily.
The question I have:
I was searching and see a post about cleaning the ignition coil off to get a better connection. I don't know whole lot about cars so sorry if this is a dumb question.
Where is the ignition coil? Im not even sure what it is..
Will I be able to take this out myself to clean it?
Can anyone take a pic of where it is and what it looks like for me, or maybe a description?
Thanks,
Will
boredguy77 Apr 28, 2003 09:33 AM
you will need more than a TC to peel out on the highway:D
DriftGirl Apr 28, 2003 10:34 AM
you mean you were at 'high way speed' and then floored it? not gonna happen with just a TC.
Nitrous or Turbo would help :)
Can be done with nitrous on an sc4, but to do it would really be hard on your tranny and motor.
ztikmedia Apr 28, 2003 10:52 AM
No, I mean from a start it wont' peel out.
DriftGirl Apr 28, 2003 11:04 AM
Get a tune-up
ztikmedia Apr 28, 2003 11:10 AM
Originally posted by Emerald
Get a tune-up
I did, less than 4,000 miles ago :(
DriftGirl Apr 28, 2003 01:08 PM
PM
qmtran May 16, 2003 11:39 PM
would it be the same in acceleration wise if i turboed the sc300 w/ auto compared to the 5 speed? or would the auto be a bit slower?
LasVegasSC May 19, 2003 05:07 AM
Auto would be Much slower since the Auto trannys are geared for comfort (Its a Lexus)
lex400sc May 19, 2003 05:06 PM
Try a brake stand. Since you have the Dragon TQ, you have a higher stall. It should be fairly easy for you to get a good burn-out going. Are you on stock wheels and tires?
Lex Luthor May 19, 2003 09:26 PM
Don't be too sure 'bout that one...
CDALTON May 20, 2003 06:31 AM
How long ago did you do the TC? If you just did it then your ECU has to learn your new setup. I have a dragon with a 3000-3200 stall and I have no problem peeling out(18" rims). If you just did the converter, see what happens after a 100 miles or so. And No I dont have to load the converter to spin the tires. Let off the brake and floor it!
Keith13b May 20, 2003 10:22 AM
Thats an understatement!! My 285's will just light w/o even flooring it.
lex400sc May 20, 2003 06:16 PM
I'm getting real tempted to splurge on a brand new torque converter now!!...
ztikmedia Jul 13, 2003 05:33 PM
Bumpin this old thread. I bought an escalade and just through the sc in the garage since I got so sick of it. Well I finally got it back out the other day, I used it to go on a trip (better gas milage) and I still can't freakin peel out. Ive put almost 2,500 miles on it. I'm going to try cleaning the ignition coil off ( I seen that in another post today).
Oh and btw, no I can't do a brake stand. It just revs up, but doesn't peel out.
Everything else on the car seams fine, I was on a long stretch road and got it up to 140mph for a few minutes. Had no problems at all.
