idle probelms because of SC400 MAF on SC300
After a week or so, i started to notice that every time i started my car in the morning it would be a very rough idle because of the mas air meter i installed from my old sc400 to my sc300. It seems to be fine once it is warmed up, so i was wondering if i should replace my oxygen sensor in my exhaust manifold to a heated one? i have a 95 sc300 and the stock O2 sensor is a one wire sensor, just 12v and it grounds to the exhaust. If it had a heated O2 sensor do you think it would help when the car is cold? Or would an S-AFC work to correct this? Anyone install an S-AFC II?
PS - I will clean up my car and post some pics for you guys, i did my Screen install w/system, rims, eibachs, tokicos, clear corners, a/f ratio gauge, built in radar detector
Originally posted by Bean
prolly because you're running SUPER lean
IIRC any OBD2 1uz MAF allows a 2jz-ge motor to run 440cc injectors with minor tuning vs the stock 330s....
if you're running the stock 330s then you need an AFC to richen some stuff up
CatManD3W
Performance & Maintenance
99
04-13-16 06:46 AM
