ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   PLEASE HELP 1jz won't start (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/798158-please-help-1jz-wont-start.html)
DirtySc300 Sep 22, 2015 06:46 AM
Alright here's the story about 2 months ago I bought my 93 sc300 swapped with the 1j had the car for about a month then it was hard starting. As the days went on it got harder and harder to start and finally when it did it would get a random misfire and not rev of 2k rpm(fuel cut,ign cut not sure) its as if it was in limp mode. So I did some testing looked over a few things and found out the ecu had a blown cap and burned the board slightly. So off to drift motion it went. So I get it back, hook the ecu back up on the first try it started right up still had that miss and would not rev past 2k then after 20 second it shut itself off and hasn't started since. Car is no longer getting spark it had spark before ecu went out don't think its getting fuel either so tonight I'll check. You guys have any suggestions?
GISguy Sep 28, 2015 06:11 AM
Bumping for this guy's sanity. :\
CatManD3W Sep 28, 2015 08:45 AM
Who did the wiring.....if so what harness are you using...???
Sounds like to me something is not wired correctly
