iacv sc400 liquid
Old Oct 12, 2014 | 11:18 AM
phillup23's Avatar
phillup23
Default iacv sc400 liquid
Im a noob. taking off the hoses that go to the iacv. is liquid suppose to pour out?
Old Oct 12, 2014 | 12:45 PM
t2d2's Avatar
t2d2
The front lower one goes to the water inlet, so yes, coolant will pour out. Ditto for the lower side ones which are coolant bypass lines to the throttle body and EGR, as I recall. The upper one over to the air intake shouldn't have any liquid in it.
Old Oct 12, 2014 | 04:07 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Well I replaced the IACV on my SC400 and I only removed one hose...lol well whatever works!
Old Oct 12, 2014 | 04:18 PM
t2d2's Avatar
t2d2
You're probably referring to just the valve itself, not the entire housing? But even then, I'm not sure what one hose you would have removed because mine doesn't have any hoses connected to the valve. And looking at one of the all-in-one units with the valve inseparable from the housing, you would still have to remove all four hoses to get it off, so that can't be it... Did you mean the one [wiring harness] plug, rather than one hose?
klein4896
Aug 31, 2008 09:37 PM
Clays93SC4
SC400 / 300 Classifieds
Mar 1, 2007 04:28 PM
VQT
Nov 8, 2001 10:43 AM
