What are these items on my SC-400 ?
SC400 (relatively new owner)
Requesting identification of a couple of items.
1.Owner's tool kit has a small chrome-plated T-handle wrench with drive end that is shaped similar to a Torx bit. What is is used on? I can't see any references to function in the Owner's manual.
2. In Passenger side of trunk, between CD-Changer/Amp and the outer quarter panel is a black plastic housing that seems empty. I don't see any electrical wiring going to it. What is function of this black-box? I'm speculating it lets air into trunk for ventilation but is supposed to prevent water infiltration into trunk. Yes/No ?? If that is the function, it doesn't appear that it does a very good job.
I couldn't answer your first question, your second one is a trunk air box, there is a flapper door on the bottom of the black box to let the air in, but not out.
If you remove it you'll see a hole and you'll see the ground. Leave it where it's at and stop messing with your lexus
(Contraband box
(Contraband box
That T handle wrench is probably for the moonroof to manually close it should the motor malfunction and stop working. And that plastic box is a vent for the trunk, except it does the opposite of what the LEXXIUM said, it's to let air out, but the flap is there to prevent air/water/debris from coming back into the trunk. Any water leaking into the trunk however, would not be from that spot. Usually it's from the worn trunk seals.
PERRYinLA
03-10-02 12:51 PM
