anyone else have these issues
Ok 92 SC 400 260k:
-reverse lights don't work
-ac console works but no air blows at all
-cluster needles don't light up
- after turning off, taking out the key and opening the door I get a "beepbeepbeepbeep!- beepbeepbeepbeep!" x8... even after exiting the car and closing the door.
-when I turn on my blinker the fog lamp on that side comes on... but they don't come on any other way...
These are tge things I can't figure out how to fix... and I can bring myself to start fixing it up until I fix them
Anyone??
Anyone??
But these issues have been that way since I got it... but i just recently found out about the reverse lights
Ok 92 SC 400 260k:
Fuse? No clue
Dead fan I imagine, or try another cc unit
Everyone has this. Use Tanin electronix
Electrical gremlin
They're cornering lights not fogs. That's oem
Anyone??
Fuse? No clue
Electrical gremlin
Anyone??
Iv replaced several fuses... but not all. I guess I'll start there...
Not sure if the fan is dead or not... but ill check that as well... the cc works, beeps and all... the screen is warped but i don't think that would stop it from working all together
Yea it happends no matter what... it's not a huge deal it's just annoying to hear as I walk away from my car... it always makes me feel like I forgot to do something
My sunroof chimer used to do that. I searched and found the circuit board and used a solder gun to remove the buzzer. There is a how too on it in the FAQ sections.
The 91-94 had "cornering lights" instead if fogs, the help when making a turn in the dark by highlighting the side you are turning too (by far my favorite feature of my car).
Ac fan needs replaced
And reverse lights could be the bulbs or wiring somewhere. Check around the shifter to see if it's stripped. Also the ECU could be bad causing the lights not to work but I doubt it.
Good luck
Good luck
Give us a call or shoot us a message
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
Yes!... that is exactly what it was... it was not "completely" closed it has to make that tight "SHOOMP!" On my IS it just closes lol so i got used to that... thanx guys one down
For your back up lamps i'd first check ur back up light switch it should be on the RH side of the Tranny, Here is your wiring diagram for the lamps check to see if there is voltage when the back up switch is closed(when in R)
For your AC/Heater I'd say either ur resistor or the blower motor it's self might have gone bad.
and all that is behind your glove box.
I believe those are the last two things you have to fix right?
Yea that's probably going to be the last thing I work on... so after I get the kits for the cluster in the climate control that will probably be the time I'll have to work on the AC....
is that going to be complex electrical or just bolt on plug and play?
