help
Old May 30, 2014 | 07:20 PM
soarer1988's Avatar
soarer1988
Default help
I got a 1jz swap in my sc the oem toyota map broke so I got a omni power 4 bar and my car wont start with it on I am using a stock ecu car is auto
Old May 30, 2014 | 07:47 PM
INTIMAZY's Avatar
INTIMAZY
You'll need at least a SAFC.
And I honestly don't know if its 50% range will even get you to make it run.
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you cant just replace the stock map sensor with a 4 bar map sensor. the stock map sensor is like a 2.3 bar and the only one that really works with the stock ecu. you need a replacement 1jz/2jz oem map sensor.
Old May 31, 2014 | 11:16 PM
soarer1988's Avatar
soarer1988
thanks every 1
2jForce
Jun 11, 2013 04:29 PM
Hostile
Oct 14, 2011 06:18 PM
meangreen1
Aug 5, 2009 06:49 PM
Yahoo27
Aug 2, 2009 04:59 PM
