ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   license plate lights doesn't work. (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/741141-license-plate-lights-doesnt-work.html)
jborje021 May 5, 2014 04:55 PM
Hi I'm a newbie here. Got my lexus last November from an old man its a 1996 lexus sc400 there's a problem with my license plate lights right now it just wouldn't work I changed the bulb it still doesn't work is there any method to fix it.
AnonymousG May 5, 2014 06:03 PM
Did you check to make sure the bulbs are getting voltage? Also make sure the connector for the harness is good also.
oldManTan May 5, 2014 06:13 PM
i have the same problem, it's really hard to get to the harness without taking the bumper off, at least i dont know of a way. you can take a tail light off and you'll have a gap then where you can check if the harness isn't cut, mines cut -_- have no idea why
Golden95SC Jan 10, 2015 07:49 PM
Same here icant figure out how to get them to turn on, all my other lights work no problem. If anyone knows please leave some input.
PJSC300 Jan 10, 2015 07:54 PM
Have you checked your fuses? I believe it was a 7.5a fuse
