sc400 diff on an sc300??
Old Mar 28, 2014 | 11:08 AM
sflsc300's Avatar
sflsc300
Default sc400 diff on an sc300??
Hey guys I have an sc300 from 92 with an r154 and I recently blew the diff and was wondering if I could drop in an sc400's 3.9 diff without having to change the drive shaft. Is it the same size? If anyone knows please feel free to comment going to get it now so the sooner the better.
Old Mar 28, 2014 | 12:08 PM
mecheng10's Avatar
mecheng10
yes.
the pumpkins are interchangeable.
I think you will have to swap the companion flange though. but im not 100% on that
Old Mar 28, 2014 | 01:19 PM
sflsc300's Avatar
sflsc300
Just measured mine and compared it to a 92 sc400 diff and the companion shaft is off by 1/16th lol
Old Mar 28, 2014 | 01:28 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
what he said, although you may want to look into the later year v8 3.2 ratio versions if you are looking for more gear up top now is the time to do it.
Old Mar 28, 2014 | 07:51 PM
Halon's Avatar
Halon
Yep, I have an SC400/430 rear diff in my SC300. Just had to swap the flange, pretty simple.
Old Mar 28, 2014 | 11:51 PM
sflsc300's Avatar
sflsc300
Thank you for all the info dudes much appreciated
Old Mar 29, 2014 | 06:03 AM
Vrank's Avatar
Vrank
That's odd, as I have an sc400 and threw a 96!auto 300 diff in mine, bolted right up
Old Mar 29, 2014 | 10:16 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I think the lower ratio ones you have to swap the flange like if its a 430 model. the 400's might be the same but its pretty easy to look at it. 1/16 off sounds like its probably the same.
Old Mar 29, 2014 | 04:45 PM
sflsc300's Avatar
sflsc300
Yeah I mesured mine next to the flage and the other one starting from the flange face. Guys quick question do you think solid diff bushings could cause the diff to just fail over time (loose teeth or even just exssesive wear)?
Old Mar 29, 2014 | 08:02 PM
sflsc300's Avatar
sflsc300
Excesive *
Old Mar 30, 2014 | 08:13 AM
Vrank's Avatar
Vrank
* excessive haha
From my research the auto 96 300 diff I threw in is a 4.27 iirc, stock was 3.9. I definitely lost like 4mpg average
Old Mar 30, 2014 | 09:28 AM
megamax's Avatar
megamax
op what do you mean by blew the diff?? iirc these are pretty stout rear ends..
Old Mar 30, 2014 | 11:57 AM
sflsc300's Avatar
sflsc300
I have a feeling the differential was spanked on before I bought the car but I went to drift a corner and it broke off two whole teeth on the gears (not ring or pinnion) if only I could post the picture of it when I cracked it open. **** wasnt pretty and the gear corresponding to the right wheel had all the teeth grinded down to almost nothing.
Old Mar 30, 2014 | 12:44 PM
Vrank's Avatar
Vrank
Probably ran low on fluid at some point. I let one seep a little too long and same thing happened. Diff low on fluid plus clutch kicks equals bad things. RIP my 4.08 factory 5 speed diff.
Old Mar 30, 2014 | 09:34 PM
sflsc300's Avatar
sflsc300
I'm gunna have to monitor the new one lol its not brand new but when I cracked it open there wasn't even a single metal shaving and the old oil still had some good color to it. Wasnt completely black.
