Sc4 Build
Old Aug 16, 2014 | 04:01 PM
  #46
toyoboy120's Avatar
toyoboy120
Originally Posted by bigwes
How hard was it to install the LS brakes on a scale from 1-10?
Brakes were easy, it's pretty basic straight foreword install.
Old Aug 19, 2014 | 07:44 PM
  #47
toyoboy120's Avatar
toyoboy120
Ok so my clutch spacer wont be here until Saturday, so I did everything I can until I get it. So I got the adapter mounted and my pilot bearing adapter in.
Old Sep 1, 2014 | 03:38 PM
  #48
toyoboy120's Avatar
toyoboy120
Update... got some stuff done, got the engine bay all cleaned up and the EGR delete done.
Did my own little intake mod. I modified the factory tube and took the bog box thing off and patched the hole. Opened up the box some on the outside and made a heat shield to block all the hot engine bay air.
Old Sep 1, 2014 | 03:50 PM
  #49
toyoboy120's Avatar
toyoboy120
Finally working on the car again!
finally got my spacer. got it and the clutch all put together.
and finally got the trans all in, had some fitting issues and had to open up the tunnel a little with a sledge.
and got the wiring for the speedo done, we'll see if it works....
The slave cylinder sits pretty close to the drivers cat so i wrapped it and the line in heat tape
Old Sep 1, 2014 | 07:02 PM
  #50
PR0PH37's Avatar
PR0PH37
Nice simple build. Hate that you are abandoning it for the 240z bit make sure you give us a few pictures here and there when you can.
Old Sep 3, 2014 | 12:37 PM
  #51
toyoboy120's Avatar
toyoboy120
I’m not completely abandoning it, just not going for the full forced induction build i was planning on. It will be more of a mild street build.
Another update, went to the driveline place and dropped off my slip yoke and measurements, ended up having to order the Driftmotion 3 bolt to 4 bolt adaptor, will be here Friday.
Old Sep 3, 2014 | 12:48 PM
  #52
tibby12's Avatar
tibby12
Any update of the Dakota Digital speedo? I also did the 6 speed swap and was looking into different options of the speedo. Also what circuit did you tap into?
Old Sep 3, 2014 | 04:07 PM
  #53
lilSCsteve's Avatar
lilSCsteve
Nice build so far! Very clean install. Hey, not sure if I've missed it or not? If you haven't moved your harness in the wheel well, you should do so immediately. This will help save the harness from getting chewed up with that right height? Keep the mods coming, and I too can't wait to see the Z finish.
steve
Old Sep 3, 2014 | 09:06 PM
  #54
toyoboy120's Avatar
toyoboy120
I'll have a update on it once i get my driveshaft. I used the abs speed sensor, I had my buddy wire it for me. I'm not as umm smart when it comes to wiring.
steve
That was one of the first things i did when i lowered it.
Old Sep 8, 2014 | 12:10 PM
  #55
tibby12's Avatar
tibby12
Im very interested in knowing how the speedo signal works for you. If it works fine then im going to order one. Been looking for one for a couple weeks and im tired of using my gps as a speedo lol. Awesome looking car btw.
Old Sep 14, 2014 | 06:27 PM
  #56
toyoboy120's Avatar
toyoboy120
update: got the rest of it together, drives pretty good. but i ran into a issue... when i pulled all the lines for the hydro fan and capped them i didn't even think about the pulley so it seized on me today. so I'm hoping someone can give me some guidance here. Ive seen people switch to the ls400 pump and pulley and i have seen some people remove the guts of the sc400 pump and run that. so not sure which to do at this point, id like to not spend the money if i don't have to at this point since Ive already spent so much on the swap...
anyway, everybody likes pictures....
also I got some 95-96 tails last week
Old Sep 14, 2014 | 06:28 PM
  #57
toyoboy120's Avatar
toyoboy120
also, quick update on the Dakota digital box... I am getting a signal but I haven't figured out how to adjust it correctly yet so its kind of all over the place
Old Sep 16, 2014 | 05:22 PM
  #58
tibby12's Avatar
tibby12
Sweet. Ive been trying to order one myself and figure it out. Need to wire one in myself and mess with it. Itll be sweet to see the speedo actually move. lol
Old Sep 19, 2014 | 08:07 PM
  #59
toyoboy120's Avatar
toyoboy120
So I ended up getting a 2uz-fe front cover and pulley. Now it's all fixed and runs perfect!
And just a little interior shot most of the way back together
Old Feb 11, 2015 | 12:36 PM
  #60
daSC4's Avatar
daSC4
Just went through the whole thread! Awesome build brother! It's been 5 months, any updates?
